ignition switch
Old Sep 29, 2009 | 06:09 PM
vett 68's Avatar
vett 68
Default ignition switch
i need help how do you get key switch out of key housing on 68 vette thanks pete
Old Sep 29, 2009 | 07:04 PM
Duke94's Avatar
Duke94
Do you have the key? There should be a hole in the front face. Stick a pin in the hole to depress the pin while turning the key (can't remember which way) and it will come out of the housing. If you don't have the key, it will have to be picked by a locksmith to remove.
Gary
...Roger...'s Avatar
...Roger...
I think you put the key in then push a paper clip in the tiny hole and turn the cylinder towards ACC and pull out.
OR you put the paper clip in then insert the key then turn the key to ACC
Old Sep 30, 2009 | 05:41 PM
vett 68's Avatar
vett 68
thanks i do have the key i would have destroyed it if not for this site thanks fot help pete
To ignition switch
