Starting problem diagnostic idea logic check needed
In order to eliminate cables and battery as the problem, I was going to put a spare battery (top post) on the ground, and run a cable from the positive term to the starter lug (after disconnecting the existing battery of course) and a jumper cable from negative to chassis ground.
If it still doesn't start, I'm fairly sure that the starter is bad. If it does, either the existing battery or the cables (or chassis ground from the battery) is bad, correct?
Also, where does the negative battery cable ground to the engine/chassis?
Thanks for your feedback
John
inside the OEM starter Solinoid is a copper disk about 2" Dia. that is supposed to make the contact to allow 12v to the starter motor, after many starts these basicaly get arced and build up resistance, which is what turns the actual starter motor, or Not .... after many years.
Thus smacking the starter sometimes will make the contact good enough to start. you can actually remove the soliniod, dissassemble it, flip the copper washer over, clean up the copper lugs, and you have a new starter solenoid.
The starter solinoid is the final switch that tells the starter to rotate.
After the Bendix has fully engaged the flywheel. (The Clunk )
The negative battery cable goes to the frame, you must also have another negative/GND. cable
going from the frame to the Engine/starter. I assume you have verifiied these cables are solid with NO corrosion.
It the battery were the problem it would crank slowly, ....no Crank at all = Bad solenoid.
69VETT
