could someone post a pic of how a 74 tail lens attaches, I know it dosent attach to the bumper but to a bracket, does anyone have a pic of this bracket?
this is the best I could do from the inside.......
but from the outside......much better shot......and they are riveted to the upper panel of the rear.....
hope this helps................................... .............Tom
I think this does a whole lot actually, the three bolt holes around the 4 larger whole that your bulbs go through, is that what the lens bolts to?
I have a 74 with an 80-82 style rear bumper on it and Im wanting to go back to the stock split tail, and Im trying to see what Ill need before I get there
Miles
that is correct..........attach your bumper, slide the light in and attach your nuts.....you may need another person to help you out, unless you have long arms...........................Tom
...I have a 74 with an 80-82 style rear bumper on it and Im wanting to go back to the stock split tail, and Im trying to see what Ill need before I get there...
The '74 tail light installation is one year only. The assembly instruction manual (AIM) will show you the parts you need and how the lights and brackets are installed.
Did you keep the original 74 set up when the 80-82 styple bumper was installed? Finding the stock '74 parts these days might be a PITA.
Im going to have my dad check to see if I have those 2 brackets that the lenses bolt to,
I bought it with the 80-82 bumper on it, so I never looked for the brackets, Im not sure whats under there (im in springfield mo and the car is in Joplin)
how are those lens brackets attach, are they something that can be removed? somehitng that could be parted off of one car and onto another?
