Frame Stencils
Old Oct 9, 2009 | 04:06 PM
Troy.Blackburn's Avatar
Troy.Blackburn
Default Frame Stencils
Did they stencil frames past 1972? I see listings for frame stencil kits for frames up to 1972 listed in several places, but don't see any past 1972.
I'm doing a frame off on my 77 and while I'm not going for a Bloomington Gold restoration... Hey I might as well put it back to original as close as I can.
I'm definately ordering the NCRS Judging Manual for 77's today.
Thank You
Troy
Old Oct 9, 2009 | 04:18 PM
mds3013's Avatar
mds3013
My '77 had white, painted on stencils. I would like to repaint them also. mds...
Old Oct 9, 2009 | 05:21 PM
BKarol's Avatar
BKarol
My 78/79 devotes about 2/3 of a page to frame stencils (white to yellow and orange-yellow),different numbers for autos and manual transmissions, dates (digits separated by dash, some with dots) and grease pencil marks in green and yellow, to assist assembly line workers in placement of shims and other items.
I'm sure 77 will have their own particulars.
Good luck.
One thing they do note that drips and runs are acceptable however if present will be toward the rear. Frames were hung with their front upward to dry.
Old Oct 9, 2009 | 05:24 PM
Mad Vette's Avatar
Mad Vette
Apparently they do, this is from the great Corvette assembly line thread on the same page. I think this is the 1980 production run.
Old Oct 9, 2009 | 05:28 PM
Troy.Blackburn
Thanks to all for the help. Does anyone have a suggestion where to get a correct stencil kit for a 77?
Thanks Again
Troy
Old Oct 9, 2009 | 06:16 PM
Troy.Blackburn
After doing a search of past threads I found a reference
Now I just need to figure out the correct dates.
Troy
Last edited by pewter99; Oct 17, 2009 at 08:28 AM. Reason: non supporting vendor link
Old Oct 9, 2009 | 08:41 PM
GPGG70's Avatar
GPGG70
Hey Troy B.
Before you commit to the good doctor, look into paragon. They have the number stencils and even where you can just buy the printed numbers for less then 25.00 if I remember correctly. You can have paragon help you with your numbers as well. They'll need your vin number.
Old Oct 9, 2009 | 08:42 PM
Droptop-Rob's Avatar
Droptop-Rob
Yes, Doc has them I got mine from Quanta
Old Oct 10, 2009 | 11:05 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Troy.Blackburn
...Now I just need to figure out the correct dates...
The frame date will be prior to the time/build date of your '77. The frame was stenciled when it was manufactured by the A. O. Smith Company. It was then shipped to St. Louis where it was probably stockpiled prior to use. It's also possible it was rained or snowed on before it went under your Corvette because frames were often stacked outside the building.
Can you read any part of the original date?
To Frame Stencils
