winter storage
Old Oct 13, 2009 | 07:18 AM
painterman52's Avatar
painterman52
Default winter storage
is it better to cover the car or leave it uncovered. there are no leaks.
Old Oct 13, 2009 | 07:30 AM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
Cover it if you have cats protecting it from critters and falling objects .The cover will protect it from anything that may come in contact with the paint....If it's a pristine environment, with no chance of anything like that happening, then don't bother....Dust will be a pain in the spring though....
Old Oct 13, 2009 | 08:52 AM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
I think a big question that needs to be answered first is: will the car be inside or outside? If outside, I wouldn't put a cover on my car, figuring the wind will cause the cover to flap and mess up the paint. I store mine in the garage at my house, so I put the cover on it to keep dust off, and to prevent the damage to the paint from foot traffic in the area. For reasons I can't explain, people walk a lot closer to my car when the cover is off than when it is on. As a general rule, I don't throw things at my car or drop things on it, so I don't really worry about protecting it from that sort of thing.
Old Oct 13, 2009 | 09:39 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Depends on the cover, and the condition of your car.
A weather-proof cover like Stormproof won't breathe and can damage the finish because they're like a windbreaker material, and trap moisture between it and the car even though it'll shed rain and snow.
Multi-layer barrier style covers like The Wall or Noah are soft and breathe, but eventually get soaked through.
My advise, if you really want to protect your car, and you have the $ to spend is to get one of each.
Put the breathable cover on first with the weather-proof cover on top.
Will you be driving the car at all during the winter? Can you rent a secure garage space for it?
Old Oct 13, 2009 | 11:50 AM
Ravine Speed's Avatar
Ravine Speed
You are in Crystal Lake, I am also in the Chicago area. Obviously assuming indoor storage.
Why wouldn't you store it with a cover? It keeps the dust off and provides some superficial protection from falling things, wandering things, walking things, etc.
If you are concerned about ventilation or moisture, get a cannister of moisture remover (near the moth ***** in drug store) put it in the car with a few handfulls of moth ***** and dryer sheets. This will keep it dry inside, keep critters out, and it will smell pretty good in the spring.
Personally, I can't think of any reason not to cover it.
Old Oct 13, 2009 | 05:32 PM
painterman52
It`s my kids car. he`s in the marines and it will be outside. the vette will be inside with a noah cover on it. His will be out with no cover.
Old Oct 13, 2009 | 09:18 PM
dannyman's Avatar
dannyman
So, his car is a vette also? Can't leave it outside all winter!
If stored outside, at the least keep it under a carport protecting it from snow accumulations. Covering it is likely to cause more paint damage than it will prevent; as mentioned, wind shifting the cover and rubbing the finish. Indoor storage not an option? That's the direction I would be heading for.
Old Oct 14, 2009 | 12:19 PM
Ravine Speed
I have the same confusion. I don't know what or whose car the original post is about...
I agree with your advice, but I'm not sure the son's car is a Corvette. I'm not really sure what his post is about.
Old Oct 15, 2009 | 12:21 PM
John Ulrich's Avatar
John Ulrich
Don't park it on grass.....even worse!
Look in Craigslist for a storage option.
http://chicago.craigslist.org/nwc/rvs/1419288111.html
Old Oct 15, 2009 | 02:28 PM
morleyz's Avatar
morleyz
I wish they had this the winter I stored my vette in @ The Keep in Crystal Lake. Unheated and more expensive. Although I was the only one with access, so I guess that was a plus.
Old Oct 15, 2009 | 07:00 PM
Paul L's Avatar
Paul L
Don't leave a Corvette outside in winter. The damage can be more substantial than a modest monthly fee for indoor storage. Many older people no longer use their garages. Check your neighbourhood for that possibility.
Old Oct 15, 2009 | 07:06 PM
jimo's Avatar
jimo
and every now and then you can take a peek to make sure she's sleeping well!!!
Old Oct 15, 2009 | 07:31 PM
rajsid's Avatar
rajsid
You really want to hear what's better?
Old Oct 16, 2009 | 10:07 AM
Derrick Reynolds
And this year, I suspect I will be taking some of the dash apart. If so, she and I will have quite a bit of quality time together, even when the roads are covered in salt!
I think there is little argument that the best way to winter store is in a garage attached to your living space that has power, light, heat etc. The car I have now is the first classic I have ever owned where I had access to that kind of winter storage, so I know what "less than ideal" storage is like.
Old Oct 16, 2009 | 11:26 AM
Rebelrob's Avatar
Rebelrob
Winter storage huh...
Down here we look forward to fall/winter, means the temps are below 90 degrees.
Every now and then we will get a few spikes to 60's and 70's during the middle of winter.
But if I lived on the Frozen Tundra of the North like all of you. I would store it in garage or at least a storage facility. It would be worth the money as mentioned above.
To winter storage
