Vacuum canister help!
Old Oct 13, 2009 | 06:50 PM
u2bdet's Avatar
u2bdet
Default Vacuum canister help!
Can anyone give me ideas on how to replace missing headlight vacuum canister?? I'm missing the unit ,bracket is there , the hoses are T'ed together and I'm thinking thats the reason for my left light rising sloooowly and after the right is up. All the parts vendors say that the part is discontinued....
Thanks...Neal
Old Oct 13, 2009 | 08:29 PM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
It helps to tell us what year Vette you have.
Check E-Bay and there are venders that have them.
here's a 1970 1971 1972
http://cgi.ebay.com/ebaymotors/1970-...Q5fAccessories
Old Oct 13, 2009 | 08:39 PM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
Thanks...Neal[/QUOTE]
Really? Eckler's, Mid America, Corvette Central, J&D Corvette, really?
Old Oct 13, 2009 | 10:39 PM
CCrane65's Avatar
CCrane65
I'm curious how the headlight goes up at all without an actuator?
cc
Old Oct 13, 2009 | 10:47 PM
temvette72's Avatar
temvette72
You can purchase a "tin-can" accumulator for about 40 bucks from any of the vendors. I imagine the original style unit from early C-3s is a salvage-only piece. You don't need the accumulator to operate the lights. It stores vacuum to allow actuation of the lights and wiper door after the engine is shut down. If your lights are operating slowly with the engine on, you probably have leaks elsewhere.
Temvette72
Old Oct 13, 2009 | 10:48 PM
...Roger...'s Avatar
...Roger...
This all you need to store vacuum.
http://willcoxcorvette.com/product_i...ducts_id=24616
edit...oops its discontinued ..... just get a coffee can and add a couple nipples or make one out of 3" or 4" PVC with caps on the ends.
Old Oct 13, 2009 | 11:02 PM
Hammerhead Fred's Avatar
Hammerhead Fred
cc
What exactly are you missing?
The headlight will NOT go up at all via vacuum if the actuator
is missing. Slow to rise headlight doors are usually due to vacuum leak
predominantly the actuator seal.
Old Oct 13, 2009 | 11:05 PM
earthquake68's Avatar
earthquake68
I made my own. I had nothing when I bought my 'Vette.
Old Oct 14, 2009 | 12:26 AM
Douglas Mariani
Pro Mechanic
Nice Job
Old Oct 14, 2009 | 09:36 AM
u2bdet's Avatar
u2bdet
The actuators are there ...just missing the can.. and I've called those vendors and was told that the part has been discontinued ,must have been recent because they list the part in their latest catalogue....
Old Oct 14, 2009 | 09:37 AM
u2bdet's Avatar
u2bdet
Its an 81 with the "coffee can" tank .
Old Oct 14, 2009 | 09:56 AM
...Roger...
Since you have the bracket and if you want it to look original just use a coffee can and solderer in some nipples,its easy.Paint it black.
Old Oct 14, 2009 | 10:16 AM
Ganey's Avatar
Ganey
Can anyone give me ideas on how to replace missing headlight vacuum canister?? I'm missing the unit ,bracket is there , the hoses are T'ed together and I'm thinking thats the reason for my left light rising sloooowly and after the right is up. ....
Thanks...Neal
There could be a leak, disconnect right & plug, then try left only. Try right relay on left.
Old Oct 14, 2009 | 10:26 AM
CCrane65's Avatar
CCrane65
The left actuator seal could be leaking. I don't think the diaphragm is leaking because it probably wouldn't stay shut if that were the case.
cc
Old Oct 14, 2009 | 10:31 AM
Virginia Vettes's Avatar
0Virginia Vettes
Former Vendor
The company that made the coffee can vacumm can has gone out of business as we used to sell them by the boat loads.
One question-- How do you get the stuff out of the full coffee can without cutting the lid off so you can make one???
Old Oct 14, 2009 | 10:42 AM
Ganey's Avatar
Ganey
Drill.
Old Oct 14, 2009 | 12:24 PM
GD70's Avatar
GD70
Call Paragon and ask for the vintage parts department, if they don't have a new replacement. Also try some Corvette salvage yards.
Old Oct 14, 2009 | 01:23 PM
...Roger...
I have some 2" fender washers minus the hole that I screw in 3 nipples in the center and solder the washer over a 1 1/4" hole. Coffee comes out the 1 1/4" hole.
If I remember right I have transferred the original 3 port to a new can. I think,but I can remember if it was pot metal and I epoxied it to the new can.
A 4" diameter piece of PVC pipe with caps on both ends works good also with 3 nipples threaded in. Just about anything can hold 20" of vacuum.
To Vacuum canister help!
