strange engine-combination
Old Oct 14, 2009 | 08:28 AM
Black Stingray's Avatar
Black Stingray
Default strange engine-combination
Hello,
my name is Uli from germany and I´m a newbie.
I´m also member of the german corvetteforum.
My car is a ´69 corvette small block with TH400
I have the problem to identify my engie.
It is not the original engine.
The block has No. 14016379 and the heads have No. 462624.
The parts should be from ´79, I think.
Intake manifold has No. 3927184 ( ´69).
Carburater has No. 7029207 (`69).
I cannot find the suffix code on the engine. The stamp pad shows only the following No. : VK261800
I cannot this No. in any list.
The german members told me, this No. would not be for a corvette engine, may be a camaro or something else ?!
Can you help me ?
Thanks Uli
Old Oct 14, 2009 | 08:53 AM
GD70's Avatar
GD70
Originally Posted by Black Stingray
Hello,
Can you help me ?
Thanks Uli
Hi Uli,
You are correct, the block & heads are from 79. The block is late production number. I didn't see anything with "VK" suffix. V would be Flint Michigan assembly plant.
Glenn
Here's a few sites for more info:
http://www.mortec.com/castnum.htm
http://corvette-world.com/corvette_1...tion_codes.php
http://www.nastyz28.com/gm-chevy-cod...-suffix-10.php
Old Oct 14, 2009 | 09:11 AM
Black Stingray
Hi Glenn,
thanks for the answer.
I know these sites, but they cannot help me, because I only have this engine ID-No.
Uli
Old Oct 14, 2009 | 09:16 AM
Mike Ward's Avatar
Mike Ward
Uli,
Is that the only thing stamped on the pad? If so, it may be an ID number from a rebuilder.
Old Oct 14, 2009 | 09:51 AM
Black Stingray
Mike,
this is unfortunately the only number on the stamp pad .
Uli
Old Oct 14, 2009 | 10:06 AM
speedreed8's Avatar
speedreed8
my 79 block has a similar number on engine pad, NO vin number. after pulling the bearings , they were dated 1981 GM, and were precision sized bearings for each main,
so i figured it was a GM service replacement block installed by a dealership.
Old Oct 14, 2009 | 10:33 AM
Ganey's Avatar
Ganey
Uli
That's what it sounded like "a GM service replacement block installed by a dealership."
It's not so much a strange engine combination, it's just not original.
Old Oct 14, 2009 | 11:18 AM
Black Stingray
Hello
would it help to contact GM directly to find out something of that number, if my block is a GM service replacement block ?
Uli
Old Oct 14, 2009 | 01:07 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Someone help me here; weren't the "800" coded blocks target engines from Chevrolet?
Old Oct 14, 2009 | 09:46 PM
Alex/plus's Avatar
Alex/plus
Very interesting
Old Nov 2, 2009 | 07:10 AM
Black Stingray
Hello,
I was on an engine - tester with my car today.
Here are the facts :
Performance : 169,9 kW = 231 HP ( at the rear axle )
Engine torque : 543 Nm
I think, that would be great facts for a small block.
I´m happy about this.
Uli
Old Jun 25, 2022 | 06:43 AM
shaggyman's Avatar
shaggyman
4th Gear
Hello,
Uli
Hi another thread resurrection! Great to see those numbers. I'm in Ireland and am looking at buying an engine that was used in a fire dept appliance to pump foam. It has the same casting number and a similar engine code VK132800. Any more info you have on your engine would be great.
Old Jun 25, 2022 | 07:10 AM
shaggyman's Avatar
shaggyman
4th Gear
I found more info, these may be Targetmaster engines or target engines the name GM used for factory crate motors prior to Goodwrench.
see below.......
GM service parts operation catalog #10 dated July 1987
"MK24800
M - Hencho (made) in Mexico
K - Built in month of November (A-L used)
24 - day of month
800 - Engine Identification number, means 1979 engine
Info taken from GM service parts operation catalog #10 dated July 1987
Note-Target-Master engines were only built in one configuration, (i.e. universal 350 V8) and were to replace any 350 production engine by using transferable parts from the production engine as needed to fit the application."
To strange engine-combination
