Tilt steering column...
Old Oct 15, 2009 | 12:37 AM
69 Convertible's Avatar
69 Convertible
Default Tilt steering column...
I have a question on tilt steering column. Someone has two tilt steering column to sell. One from a 74 vette and the other from a 69. I have a 69. Both suppose to be in good condition. If I buy one, which is the better of the two? 650.00 Thanks
Old Oct 15, 2009 | 01:13 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
There is one main difference between the 69 and 74. On the 69 the raised area by the key that says LOCK. One has rounded corners and the other has square corners. For the life of me now, I can't remember the right one for the 69. All things being equal, get the 69 unit.
Old Oct 15, 2009 | 05:08 AM
Gordonm's Avatar
Gordonm
Other than what is mentioned above the 69-75 columns are the same. Buy the one in better condition. I just did this swap myself and ended up taking the whole column apart and redoing it.
Old Oct 15, 2009 | 08:19 AM
Jim Shea's Avatar
Jim Shea
with everything said above. You can purchase the one in the best condition without worrying about fit problems. (Assuming the seller knows what he/she is selling.)
Jim
Old Oct 15, 2009 | 05:31 PM
69 Convertible
Is there something to check to make sure it's in good condition? And is that a good price vs buying a new flaming river one for alittle more?
Old Oct 15, 2009 | 06:20 PM
eagle275's Avatar
eagle275
I'm going Flaming River.
Old Oct 15, 2009 | 07:15 PM
Jim Shea's Avatar
Jim Shea
The steering columns designed and manufactured by Saginaw Steering Gear Division for the C3 Corvettes are the only ones that were tested and validated in actual proving grounds crash tests to function correctly as a complete system in a real world test.
Here are some more of my thoughts on the subject if you are interested:
http://jimshea.corvettefaq.com/wp-co...gid-design.doc
Jim
Old Oct 15, 2009 | 07:46 PM
ahphares's Avatar
ahphares
I agree with Jim. I always feel a little aprehensive driving my '65 with a 3 ft steel spear pointed at my chest. Collapsible columns were a great invention!
Andy
Old Oct 15, 2009 | 08:00 PM
Gordonm's Avatar
Gordonm
Flaming river does not make a T&T column for the later C3 cars. 68 and earlier they do, but not the 69 and later cars.
Old Oct 15, 2009 | 09:56 PM
eagle275's Avatar
eagle275
yes they do.I'm getting ready to order one for my 1971. Already talked to them.
http://www.summitracing.com/search/b...?Ns=Rank%7cAsc
Old Oct 15, 2009 | 10:12 PM
Gordonm's Avatar
Gordonm
This must be somewhat new. When I was looking for mine they did not have any with the key in the column.
http://www.flamingriver.com/index.cf...rod/prd407.htm
I did mangage to pick up a good used one from a 74 for 150 and rebuilt it with about 60 bucks worth of parts. The Flaming River ones are nice but pricey.
Old Oct 15, 2009 | 10:41 PM
vettebuyer6369's Avatar
vettebuyer6369
I put a '73 in mine. Unless you are building a hot rod, I'd put a GM correct looking one in there rather than some aftermarket part. Looks way better.
Old Oct 15, 2009 | 10:45 PM
eagle275's Avatar
eagle275
Default yep.........
They are new.
Old Oct 15, 2009 | 10:47 PM
eagle275's Avatar
eagle275
From what I was told, they look GM correct.Hey, I'm the one that shoulda got the Vintage Air A/C unit, but got Hot Rod Air, so what do I know? LOL!(and I'm sure that in 5 yrs,I will regret it)
Old Oct 16, 2009 | 01:36 AM
vettebuyer6369
They do? I was told they looked "street rod" ish. My mistake.
I loooooove your avatar.
Old Oct 16, 2009 | 02:02 AM
eagle275's Avatar
eagle275
Thanks! There's alot of good ones to use. As far as steering column? Don't know. Guess I'll have to look at one up close.
To Tilt steering column...
