c3 Exhaust kits
Old Oct 22, 2009 | 07:44 PM
enroberts's Avatar
enroberts
Default c3 Exhaust kits
Hi guys, I know it's been a while since I've given updates on "the other steel cities gray" vette but all I can say is that it's getting there. The block is in and I'm getting it ready to fire up.
Can someone give me some options on exhaust kits? I'd like headers, pipes, and mufflers. I found one on corvettecentral.com with patriot headers, pipes, and magnaflow mufflers for $670 shipped. Do you all know of any others? Thanks, Neal
Old Oct 22, 2009 | 08:29 PM
Grumpy 427's Avatar
Grumpy 427
I bought a set of Patriot headers from Summit, and a 2-1/2" exhaust kit from Bairs corvettes. Have not put it all together yet, but i ended up with the stock type quiet mufflers.
Old Oct 22, 2009 | 08:44 PM
Kahle76's Avatar
Kahle76
Put the corvette central kit on last month and was very happy.
Old Oct 22, 2009 | 08:52 PM
enroberts's Avatar
enroberts
you wouldnt happen to have a video showing what the car sounds like would you?
Old Oct 22, 2009 | 08:59 PM
Kahle76's Avatar
Kahle76
If I remember correctly, you can find the video on their web page.
Old Oct 22, 2009 | 10:59 PM
72LS1Vette's Avatar
72LS1Vette
If you want a non-standard looking exhaust Magnaflow has some new stainless systems. This one is a 2.5" system for a bog block that I'm using with the LS1. It's made to mate up to the stock manifold but the pipe in front of the crossmember can be modified to connect to a header.
Rick B.
Old Oct 23, 2009 | 09:04 AM
SAMMAN's Avatar
SAMMAN
2016 C2 of Year Finalist
Rick B.
Rick,
Did you fabricate the x pipe or did it come with the system?
Sam
Old Oct 23, 2009 | 06:25 PM
72LS1Vette's Avatar
72LS1Vette
Originally Posted by SAMMAN
Rick,
Sam
It's part of the kit. If you look up the 16841 system on the Magnaflow website you can see what the components look like. I'm using the big block system because I wanted the dual tips. For some reason they put a single tip on the small block system.
Rick B.
Old Oct 24, 2009 | 12:15 AM
70Donnybrooke's Avatar
70Donnybrooke
I have the factory manifolds running the corvette central 2.5 inch factory bent magnaflow system.
Old Oct 24, 2009 | 01:18 AM
stock76's Avatar
stock76
I have the Corvette Central true 2.5" dual system w/ Magnafows bolted up to the stock factory manifolds. Installed with no issues, everything fit like it was supposed to.
To c3 Exhaust kits
