evaporator & condenser help
Old Oct 24, 2009 | 07:50 PM
nightprowler's Avatar
nightprowler
Default evaporator & condenser help
I need to buy an evaporator core and an a/c condenser for my '72 small block. I am confused with the price difference. I found that Dr. Rebuild and Eckler's has each part for $300 +. I found the same? parts from OE Parts HQ, Parts 123 or E-Bay for a little more than half that price. I want to get quality parts that install with no modification.
Thanks for any help.
Old Oct 24, 2009 | 11:26 PM
chvet73's Avatar
chvet73
I bought my parts from ackits in Arizona. Best prices and I have had no problems with them.
Old Oct 24, 2009 | 11:28 PM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
I would always try to get OE ACDELCO parts first before I would look at buying repo parts.
Old Oct 25, 2009 | 11:13 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by nightprowler
...I want to get quality parts that install with no modification....
Then be careful with eBay. Unless you are 100% certain what is being advertised on eBay is exactly what you need, stick with the better known aftermarket providers. Do not trust the item pix in eBay listings; contact the seller to ensure the item being listed is actually as pictured.
Old Oct 25, 2009 | 04:48 PM
nightprowler
Thanks for the replies. I was trying to find the parts cheaper but I am unsure of the quality the cheaper they are. I went ahead and ordered them from Eckler's. They are on the other coast and also have a 15% off sale going on right now. I really wouldn't be saving that much buying from someone else. This is my 4th. order from them, so far I am impressed with the parts that I have received. My '72 small block is getting mechanically restored, motor, trans., suspension, steering, headlights and wipers. The car has a/c but the compressor is missing. Since we are going into cooler weather, I will have all new parts ready to install for the Spring. I also have a new interior that I bought 4 years ago that will be installed once I get the car back. I hope to have it back by the end of December.
Old Oct 25, 2009 | 05:45 PM
Douglas Mariani
Pro Mechanic
I sounds like your on the right track & good luck
To evaporator & condenser help
