"O" Ring Size ???????????????
Old Oct 25, 2009 | 06:39 PM
Richard Cooper's Avatar
Richard Cooper
Default "O" Ring Size ???????????????
Hi there, I have a 1981 corvette with a TH 350 C transmission. It has a lock up torque converter. I need the little "O" ring that goes at the end of the shaft. Can't seem to locate it anywhere. I have a hugh supply of "O" rings at work and thought if I had the measurements I could match it up at work. TIA.
Old Oct 25, 2009 | 10:23 PM
John A F's Avatar
John A F
In the past I have been able to make a too large diameter O-ring fit by cutting it down. Use a very sharp razor, cut the ends square and glue back together with a dab of crazy glue. I have done this many times on Caterpillar construction equipment and it can withstand a 3000 psi hydraulic system.
Old Oct 27, 2009 | 01:17 AM
Richard Cooper
Thanks John, anyone else?
Old Oct 27, 2009 | 08:41 AM
moosie982's Avatar
moosie982
Well, not to break 'em on you but you'd probably get more answers if you said which shaft. Cant help ya other then to say when I need an o'ring I just try to match it up, unless it has a specific part #. Good Luck. Peace,,,Moosie
Old Oct 27, 2009 | 01:37 PM
jimvette999's Avatar
jimvette999
https://www.wittrans.com/SchematicPa...C&LinkCode=380
12 cents + shipping
Jim
To "O" Ring Size ???????????????
