helpppppp
Old Oct 25, 2009 | 08:33 PM
69ragvette's Avatar
69ragvette
Default helpppppp
purchased my first vette 69 rag top bought from a friend ha ha this car was race car? had been hacked .i have learned to do fiberglass repair some what but keep getting conflicting advice on whether to gelcoat or not?if so what kind ? spray on ? also have been using only evercoat polyester resin $90.00 a gallon stay with this or use somthing else? this car had several crackes and holes cut into it. thank you
Old Oct 26, 2009 | 11:03 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
There was no factory gel-coat. Any good primer/surfacer should work fine without the additional expense of the gel-coat after you ocmplete the body work.
