81 Parking brake light
Old Oct 31, 2009 | 04:12 PM
BERIN's Avatar
BERIN
Default 81 Parking brake light
Can't get the parking brake light to go out, I unplugged the white and tan wire coming from the switch but it still stays on. Any Ideas....
Old Oct 31, 2009 | 04:33 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I am wondering if the brake fluid may be low or may have been low and the light is coming from the switch on the proportioning valve.
Old Oct 31, 2009 | 10:29 PM
BERIN's Avatar
BERIN
Had not thought of that ill give it a look
Old Nov 1, 2009 | 09:36 AM
Duke94's Avatar
Duke94
Pull the wire off the proportioning valve switch. If the light goes out, then you have a service brake problem as Eddie70 suggested. If it stays on, then the issue is with the PB lever switch or either of the connector wires is shorted to ground someplace.
Gary
Old Nov 2, 2009 | 12:30 AM
mydejavooo's Avatar
mydejavooo
And I thought yanking the bulb out was a better solution than black electrical tape over the brake light indicator!!
Trevor
Old Nov 3, 2009 | 10:29 PM
BERIN's Avatar
BERIN
Thanks Eddie, my rear brake res was empty, now i have to find out why. Theres no fluid on the ground and I run dot 5 fluid, ill pull the tires. THANKS
To 81 Parking brake light
