help: engine pad number
Old Nov 10, 2009 | 06:31 PM
pablito's Avatar
pablito
Default help: engine pad number
hi, can you help me to get my correct engine pad..
the car is coupe 454 ls5 of 1970, the VIN is 194370s417064
thanks!
Old Nov 10, 2009 | 07:34 PM
joewill's Avatar
joewill
it is hard to understand your question, can you go into greater detail what you are asking?
Old Nov 10, 2009 | 08:03 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
The engine stamp pad is located in the front of the engine, where the block protrudes from underneath the passenger side cylinder head. Take a picture and post it. It should contain two stamps, the one on the left is the engine stamp and the one on the right is the VIN derivative stamp.
Old Nov 11, 2009 | 01:18 AM
pablito's Avatar
pablito
sorry!
becouse is not possible read the numbers, and so i would like to know rhe right numbers combination..
one time i found a vin decoder and the car is made in july of 1970, but know i can't find it..
Old Nov 11, 2009 | 01:31 AM
avner's Avatar
avner
Try this link:
http://www.nastyz28.com/sbchevy/sblock.php
http://www.chevy-camaro.com/chevy-ca...es.asp?group=4
Avner
Old Nov 11, 2009 | 08:43 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by pablito
...becouse is not possible read the numbers...
Clean the pad on the block. Unless the stampings have been machined away, they will probably begin to show up. Degreaser, scotchbite pad or steel wool, elbow grease. You are looking for stampings similar to these:
The time/build code for your car is in the upper right corner of the trim tag on the driver's door hinge post. A '70 assembly in July will have an G in the code for the month. The two numbers stand for the day of the month. G01 would be July 1st. July was the last month of production for the '70 models.
Old Nov 11, 2009 | 10:45 AM
Mike Ward's Avatar
Mike Ward
sorry!
The VIN code missing from your pad can be easily determined. The engine assembly date code would only be a best guess, possibly wrong by up to six months.
If yours has been machined away, why bother worrying about it?
Old Nov 11, 2009 | 10:52 AM
71 Green 454's Avatar
71 Green 454
thanks!
Vin number 194370S417064
Car History:
1970 LS-5 CORVETTE COUPE. 454 CU. IN. ENGINE. 4-SPEED TRANSMISSION.
FACTORY AIR CONDITIONING. POWER STEERING. 16,641 TITLED ACTUAL MILES.
ENGINE: 454 cu.in. LS-5 period correct Replacement Block, Original Cylinder Heads, Double forged Aluminum Pistons, Performance Cam Package/Hi-Rev Hydraulic Lifers, LS-6 Intake Manifold with correct Holly 780 CFM double pump Carburator, MSG Ignition, Hooker Headers with Chrome side Pipes. The engine has less than 100 miles since complete rebuild with all new Bearings, Gaskets, etc. It is balanced and produces over 500 Horsepower.
PAINT AND BODY: Complete body-on restoration finished 1-10-09. The project included over 300 hours stripping the body to bare fiberglass and prep with a complete paint job in Bridgehampton Blue applied personnally by Chuck Jugans (of Indy car fame). The bumpers were re -chromed and all new weather stripping throughout the car. The paint and body are absolutely perfect.
INTERIOR: The interior is all new in 1970 year correct Bright Blue. Replaced complete dash, console, door panels, Thermo-Tex insulation, carpet front and back, storage compartment, seat covers, sun visors, trim and weather stripping.
MECHANICAL: Complete new wiring harness, motor mounts, front and rear kits including; all new bushings, hoses and belts, new clutch and flywheel, complete new vacuum system regulators, hoses, and pump to keep vacuum presure at 12psi, so no annoying problems with headlights and A/C controls. All control, lights and gauges (except clock) in excellent working order. This car is not for the faint of heart. It is a ground thumping example of American Corvette muscle with over 500 horsepower. Remember this car has less than 100 miles since the completion of the body-on restoration. 16,641 miles. Colors from the owner. January 12, 2009.
Source:
http://www.c3registry.org/index.php?...11-11&uid=7918
Old Nov 11, 2009 | 11:05 AM
Mike Ward's Avatar
Mike Ward
Nice sleuthing.
Here's some more background:
http://forums.corvetteforum.com/c3-g...ese-specs.html
Old Nov 11, 2009 | 12:11 PM
71 Green 454
Originally Posted by Mike Ward
Nice sleuthing.
Yes, it sounds like he knew he was buying an LS5 with a replacement block, which won't have the vin stamping.
So Pablito...just enjoy the car!
Old Nov 11, 2009 | 12:59 PM
pablito's Avatar
pablito
yes, thanks to everybody!
i bought the car in february..and it has the replacement block.
i found the site:
http://www.c3registry.org/index.php?...lator&uid=4966
Approximate birthday 194370S417064: July 30, 1970
Old Nov 11, 2009 | 01:15 PM
pablito's Avatar
pablito
ok, i found it!
http://www.c3registry.org/index.php?...15735&uid=4312
but the mine should has the the suffix CZU
Old Nov 11, 2009 | 01:28 PM
joewill's Avatar
joewill
Maybe to specifically answer your question.. if your car had the original engine:
then your block casting date should be around july 1, 1970 ( plus/minus a couple of weeks)... the numbers on the left of the pad should be TXXXXCZU, where XXXX should be a month and a day code.. perhaps somewhere around 0715. the right side of the pad should be 70S417064. of course then you have specific fonts that will need to be used for each letter and number and perhaps a 'I' instead of a '1' in special cases.. don't forget the broach marks.. and don't forget the cast numbers and dates numbers on the transmission/heads/intake/carb/exhaust need to be pretty close to that also..
Your car was built in the final 2 days of corvette production in 1970...
Old Nov 11, 2009 | 01:50 PM
Mike Ward's Avatar
Mike Ward
then your block casting date should be around july 1, 1970 ( plus/minus a couple of weeks, or maybe minus a couple of months)... the numbers on the left of the pad should be TXXXXCZU, where XXXX should be a month and a day code.. perhaps somewhere around 0715 or maybe months earlier.
Fixed it for you. As stated earlier, the variations in engine ***'y casting and date can be up to six months.
Old Nov 11, 2009 | 01:57 PM
Mike Ward's Avatar
Mike Ward
ok, i found it!
The one in the pic is also a small block. Very different stamp pad config.
Do you plan on re-stamping your pad?
Old Nov 11, 2009 | 07:45 PM
Faster Rat's Avatar
Faster Rat
...and another "matching numbers" car soon to be born.
To help: engine pad number
