Hooker Headers Questions
Old Nov 11, 2009 | 06:48 AM
nightprowler's Avatar
nightprowler
Default Hooker Headers Questions
I know that the "header-side pipe" questions are all over this board. I am thinking about buying a set for my '72 small block. Summit sells these painted black. The price is reasonable at approx. $900.00 for pipes, headers and mufflers. With high temp paint, how long would it be before they would need paint again? I know Jet Hot sells these already coated but for $700.00 more. Is it worth it to pay the extra money now to avoid early replacement because of rust and corrosion later?
Old Nov 11, 2009 | 07:45 AM
schmegeggie's Avatar
schmegeggie
The high temp. paint will last exactly 1 heat cycle. I bought the cereamic coated Hookers(block huggers). Because my timing wasn't dead on when we first fired it up, it cooked some of it. I'm thinking of sending them off to Jet Hot this winter for coating.
Old Nov 11, 2009 | 11:40 AM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
Actually if you call Jet-Hot up they give a corvette forum discount and they end up being about $1200 for the coated setup.
Old Nov 11, 2009 | 07:47 PM
C3 Stroker's Avatar
C3 Stroker
The coating is worth it; you'll be buying new headers every year without it......header paint lasts about a good month before starting to disappear.
Old Nov 12, 2009 | 06:54 PM
nightprowler
Thanks for the info.
How long does the Jet Hot coating last before showing it's age?
Would I need shields or is the heat tolerable?
Old Nov 12, 2009 | 07:34 PM
Gordonm's Avatar
Gordonm
I have had the Jet Hot coated header pipes for about 5 or so years and it still looks very good.
Old Nov 12, 2009 | 08:18 PM
dmeesq's Avatar
dmeesq
How do the chrome headers hold up?
Old Nov 12, 2009 | 08:28 PM
Bangkok Dean's Avatar
Bangkok Dean
You will need some sort of shielding as they get really hot and will burn yours or your family's legs. There are several shields on the market, do a search.
Old Nov 12, 2009 | 10:37 PM
emmvette's Avatar
emmvette
My chrome Hooker headers / pipes are over 15 yrs old. I'm removing them and reinstalling them while preparing for paint. Unfortunately they were installed on the wrong side, so the tabs face up instead of down. My car has 38k miles, so they don't have a ton of use, but I'd say plenty.
Old Nov 12, 2009 | 10:59 PM
dmeesq's Avatar
dmeesq
Does the chrome still look ok?
Old Nov 12, 2009 | 11:46 PM
emmvette's Avatar
emmvette
Yes, they look great. They have been well kept, and I do put a bit of effort into polishing them once / year.
Old Nov 13, 2009 | 12:07 AM
emmvette's Avatar
emmvette
Nevermind the rock chips, scratches, etc, it will all look better in a few months.
Old Nov 13, 2009 | 12:15 AM
dmeesq's Avatar
dmeesq
Looks good but how do the headers look by the engine? Discoloration? Rust?
Old Nov 14, 2009 | 07:31 AM
nightprowler
I found this PDF off a Hooker website.
"WARNING! Breaking in an engine with ceramic coat headers WILL result in damage to the coating and will VOID the warranties. Ceramic-coat headers require several heat cycles to fully cure before they will withstand extreme heat. Hooker recommends using a cast-iron exhaust manifold or an old header to break in new engines to avoid coating damage."
I have a new engine going in my car. According to Hooker I would need to run my old exhaust until my new engine is broke in.
Will someone please explain the above paragraph.
How many miles does it generally take for this to happen?
Old Nov 14, 2009 | 08:21 AM
Phil Zell's Avatar
Phil Zell
I believe the tabs have to be in the up position for your rockers to fit. Mine are
Old Nov 14, 2009 | 12:06 PM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
I bought a set from one of our previous supporting vendors and asked the same questions. He sent me a picture of his car that had chrome on for many years. They still looked great but had a little bluing right at the heads and down-tubes but the rest looked like new. I'll see if i can find the pic and send it to you.
Terry
NP, PM'd you with the link to Kevin's thread with pics of his pipes (also below). According to Kevin, the pipes have been on the car since the early 70's. Not the greatest pics for this purpose but then again they weren't showcasing the pipes at the time.
http://forums.corvetteforum.com/c1-a...rod-handy.html
Old Nov 15, 2009 | 03:05 PM
nightprowler
Default Engine break-in w/ceramic-coat headers??'s
To Hooker Headers Questions
