Tricks to remove Hooker side pipes?
Old Nov 12, 2009 | 10:42 PM
emmvette's Avatar
emmvette
Default Tricks to remove Hooker side pipes?
I'm removing the side pipes and am currently stuck trying to separate the side pipes from the headers. I've not done this before, but assume they just twist/slide off to separate, and are being stubborn from years of heat cycling and possibly a little internal rust. Any suggestions on how to be best do this? I'm re-installing them on the the opposite sides because they were installed on the wrong side - which means the mounting tabs on showing on the top! The PO told me he had them installed in the 70s or 80s, he could not recall, so they have been on a long time. Any guidance will be greatly appreciated.
Old Nov 13, 2009 | 04:46 AM
samh's Avatar
samh
If they're really stuck the only thing that'll work is heat. Lots of it (acytelene). Just went thru this last summer. Heat it up around the collector tube and it'll come off.
Getting a ruster muffler insert out is a whole 'nother story.
Old Nov 14, 2009 | 08:02 AM
Duke94's Avatar
Duke94
Soak the joint with PB blaster penatrating oil for a few days. Then use a 2x4 and BFH and pound on the mounting bracket with the 2x4. Wiggle it up/down/sideways from time to time as you try to work it off. When to reassemble them, use lots of antiseize at the joint.
Gary
Old Nov 14, 2009 | 11:20 AM
Glassbowtie77's Avatar
Glassbowtie77
Originally Posted by Duke94
When it's time to reassemble them, use lots of antiseize at the joint.
Gary
That's exactly what I did when I put mine together. I haven't had mine apart since, but That is what I read on this forum, makes sense to me.
Old Nov 14, 2009 | 11:57 AM
1Fordman's Avatar
1Fordman
I use a nylon fabric strap wrench, wrap it around the mufler, cinch it up and start turning back and forth and it'll twist right out.
Old Nov 15, 2009 | 01:08 AM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
Since heat makes metal expand, I've always found that a quick way to make the tubes separate is to lay a bag of ice on the joint for 5-10 minutes. The contraction of the metal is sometimes great enough to loosen the pipes by hand. The strap wrench is a good idea as well
Old Nov 15, 2009 | 03:04 AM
Mewn's Avatar
Mewn
I set a 2x4 on the rear mounting tab and tapped it with a hammer.
Old Nov 15, 2009 | 07:28 AM
xpoc454's Avatar
xpoc454
Can hooker headers be re-chromed once they are taken off? I have a set that probably could use a touch up down the road.
Old Nov 15, 2009 | 08:07 AM
Glassbowtie77
Send them out and get them JetHot coated.
Old Nov 15, 2009 | 11:08 AM
cottoneg's Avatar
cottoneg
Gary
PB Blaster is GREAT stuff. Usually works pretty quickly.
Try it along with the other advice and they will come off.
To Tricks to remove Hooker side pipes?
