Looking at a c3
the owner says the paint (it's white) is starting to get very thin black lines in it (only seen up close)
I want to fix this if i were to get it, but i don't want it to be expensive, and it doesn't have to be a great job. is it possible to just get a coat of white and then a clear coat on top of it? would that work? what do you suggest?
how much would it cost? it's a 78.
I hear a buffer or a good wax may help out..any suggestions?
thanks!
thanks!
Good luck, and keep us posted!
Trevor
The longer you own the car, the more things you will notice need some TLC or even replacement. Some things can wait, while others are a priority. Good rule of thumb, make sure it will start, run, accelerate, brake, and steer. Then make sure that the lights all work the way they should. I had a 78, then an 89, and now my 80...and the nice thing with the older cars is that you can actually work on them. If you have any mechanical aptitude at all, you can do it. Just take your time...don't get overwhelmed by the sheer number of things that you need to do...just focus on one area at a time. If it helps, get a notebook or journal, and start writing down the things that you KNOW are needing attention...the things that are just plain broken...and then the stuff that you would LIKE to do to the car. You may quickly find that there are more MUST-DO's than want-to's...but that's what you get when you buy a 30+ year old car. If you are fine with that, then let the good times roll!
Also, take pics of the vehicle in it's present condition. This will allow you to look back and and actually see progress on the car. This can be tricky to see if you are working on it all the time, but a photo-journal will also let others see what you are doing. I personally find it very rewarding to work on my car, and change things around to my liking. This may even be something as simple as fixing inoperable wipers...wiring, etc. Everyone gets something different from working on their cars, and I'm sure you will find enjoyment there as well.
Again...don't give up. Don't lose sight of what you WANT the car to be. This will give you something to shoot for, and will make all of your hard work that much more satisfying in the end. I'm here to lend a word of advice where I can, and this forum is a great place to pick other people's brains. Let me know if I can help out!
Trevor
it's gonna be about 5000. does that sound good?
it's got a new dark blue cloth interior. needs a couple random parts (about $250 worth) everything else is good
Trevor
