Ignition switch wires
Old 12-01-2009, 09:06 PM
TOM B1
TOM B1's Avatar
Default Ignition switch wires
I have a 69 vette that I took out the wiring harness, it was junk.
I cant find the correct wire diagram for the ignition switch.
The colors on the ignition switch plug are, White, Red, Green, Blue, Brown, Orange.
In my 69 assembly manual the ignition switch diagram has a purple pink, red, green and so on, but not the right colors.
Anyone run into this, or have the right wiring diagram.
Please help.
Old 12-01-2009, 09:16 PM
MakoShark72
MakoShark72's Avatar
Try here..a great deal, its FREE!1 I got one for my 72.
http://forums.corvetteforum.com/c3-g...or-anyone.html
Rob
Old 12-01-2009, 11:16 PM
TOM B1
TOM B1's Avatar
I sent him a PM but dont know if he is still doing it.
Someone had to have the same problem with there 69.
Old 12-02-2009, 08:43 AM
Brewmeistergi
Brewmeistergi's Avatar
Looking at my 69 wiring diagram, it shows a pink wire in a white connector in the upper left terminal position (looking at the open end of the connector), a purple w/a white stripe in the lower left position and a brown wire in the upper right position. There seems to be a separate black connector that only has a red wire in the middle right position, the other positions are blank.
Hope this helps.
To Ignition switch wires
Quick Reply: Ignition switch wires
