72 fan speeds
Old Dec 3, 2009 | 06:36 PM
UHF's Avatar
UHF
Default 72 fan speeds
On the controller for the fan, there are 4 spots, off and 1,2,3. The fan runs on off. However, when the vent selector is off, i.e. not on a/c, heat, vent, etc. the fan is off.
Normal or the first indent, far left of the fan speed switch should turn the fan off even if the selector is on heat?
Old Dec 3, 2009 | 07:43 PM
CCrane65's Avatar
CCrane65
This is confusing. Do you mean the function selector on the left? There is no "vent" selector per se.
The fan runs anytime the heater is on even if the fan speed switch is off. Has to do with the Astro Ventilation.
cc
Old Dec 3, 2009 | 11:58 PM
72ls5fla's Avatar
72ls5fla
The only time the fan will be off is when the selector wheel is in the OFF position.
If it is moved to any of the other positions, the fan will run even with the fan switch pushed all the way to the left.
This is a feature that exists in AC cars only (pretty sure).
Old Dec 4, 2009 | 09:30 AM
CCrane65's Avatar
CCrane65
Bill, I believe you are correct about this being an A/C feature. I read that they did this to make up for the sealed Astro Ventilation doors on the rear deck.
On non-A/C cars, the doors open for ventilation whereas on A/C cars they sealed them to make the A/C more efficient.
cc
Old Dec 4, 2009 | 10:18 PM
UHF's Avatar
UHF
Ok, guess mine runs all the time. Thanks all. I'd prefer it didn't. Any way to have it NOT run all the time?
Old Dec 4, 2009 | 10:31 PM
Attfay Elleybay's Avatar
Attfay Elleybay
probably remove the diode for the lowest speed setting. maybe
Old Dec 4, 2009 | 11:20 PM
CCrane65's Avatar
CCrane65
Re-engineer the fan relay maybe.
cc
To 72 fan speeds
