Pulling Center Instrument Cluster Bezel
Old Dec 8, 2009 | 01:14 PM
UHF's Avatar
UHF
Default Pulling Center Instrument Cluster Bezel
How do you get to the two bolts under the dash on the bottom of the Center Instrument Cluster Bezel?
Is it a nut? Cannnot feel anything there but the threaded shafts yet it won't pull out.
Old Dec 8, 2009 | 01:26 PM
bradc6's Avatar
bradc6
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
National Champs Gators 4 St. Jude '09
http://willcoxcorvette.com/instructi...8-76_new_2.pdf
Old Dec 8, 2009 | 01:32 PM
...Roger...'s Avatar
...Roger...
Just imagine the tool in the pic going under the console. Thats how I get the nuts off.
Old Dec 8, 2009 | 02:07 PM
RagTop69's Avatar
RagTop69
When you want to reassemble the dash, how do you get those nuts started on the studs?
Old Dec 8, 2009 | 02:20 PM
MakoShark72's Avatar
MakoShark72
If the radio is out its much easier. You can reach thru the radio hole and start them "blind"... You can actually get a 1/4" ratchet in there to tighten them up, again you have to do it by feel... However you decide to get to them, its not easy!!
Good luck,
Rob
Old Dec 8, 2009 | 02:23 PM
RagTop69's Avatar
RagTop69
I am assuming that removing and reinstalling that center bezel is the only way to get to my clock, which is right two times a day. I think I understand how to get the clock working again, but it looks like removal and installation is a big PITA.
Old Dec 8, 2009 | 02:25 PM
MakoShark72
You're right, on both counts!!
Rob
Old Dec 8, 2009 | 02:26 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...how do you get those nuts started on the studs?...
The reinforcement bracket under the console has U shaped slots for this. Start the nuts on the studs before positioning the bezel , slide the studs into the reinforcement bracket as you position the bezel.
Old Dec 8, 2009 | 02:53 PM
UHF's Avatar
UHF
Most excellent! Thanks all. Got my project for the night lined up now. Well, kick pannel speaker on driver decided not to work after I re wired. I goofed up something.
To Pulling Center Instrument Cluster Bezel
