Rear Bumper Braces (Outer)
Old Dec 11, 2009 | 10:10 PM
kaiserbud's Avatar
kaiserbud
Default Rear Bumper Braces (Outer)
My 1969 does not have the braces that mount from the rear outer corners of the frame to the outer bumper bolt at the 1/4 panel.
I think they started in 1973??? and are parts 331868 and 331864?
Anyway - I forgot to check into drilling holes in my frame to accept these before I put the body back on.
If someone could supply pics, I could see how they mount and maybe figure if there is enough room to drill the holes now.
Old Dec 11, 2009 | 10:35 PM
wills670's Avatar
wills670
This is the best I can do. This is a pic. of the frame on my 72 and as far as I know 72 was the first year for the small brace you are asking about. Hope this helps.
Old Dec 11, 2009 | 11:12 PM
wills670's Avatar
wills670
Here is one more. The best I remember the braces go attached to the outter holes and they had nuts welded onto the back of the holes.
Old Dec 11, 2009 | 11:34 PM
DZRick's Avatar
DZRick
Are you talking about these?
http://www.ecklers.com/product.asp?p...6&dept_id=1442
Or these?
http://www.ecklers.com/product.asp?p...6&dept_id=1497
Old Dec 11, 2009 | 11:49 PM
wills670's Avatar
wills670
I think this is the bracket he is asking about.
http://cgi.ebay.com/ebaymotors/1972-...Q5fAccessories
Old Dec 12, 2009 | 09:48 AM
kaiserbud's Avatar
kaiserbud
Thanks - I am talking about the rods. Thanks for the clarification. I see in your recent pic there are 2 holes in the rear portion of the frame. I believe it is the outermost hole, as the only hole my frame has is about 2.5" inward. I did checked it out a bit more this morning and I do have the correct rods.
As for drilling the hole - the time for doing that was when the body was off - but I can still get to it and will have to work with a dremel to round it off nicely.
And I guess your link answers the availability for years 72-73.
Old Dec 12, 2009 | 10:10 AM
avner's Avatar
avner
kaiserbud: Here is a copy from 72 AM
Avner
Old Dec 13, 2009 | 10:08 PM
kaiserbud's Avatar
kaiserbud
I assume that there is simply a hole in the frame and it does not a welded nut on the frame.
To Rear Bumper Braces (Outer)
