Welding experts - help
Old Dec 12, 2009 | 04:22 PM
rajsid's Avatar
rajsid
Default Welding experts - help
Hi guys,
How much should a welding job like this cost (see pics)?
I am assuming that this is a simple job.
I have done all the prep work. All that the welder has to do is just weld the tube in and weld close the hole with the supplied patch.
I got an $80 quote for this.
Old Dec 12, 2009 | 04:56 PM
SIXFOOTER's Avatar
SIXFOOTER
It shouldn't cost that much, but it will. Guy in a shop will bill you an hour and spend almost that much time. Kind of a lot for a $20 job tho
Maybe see if you can get a rubber plug and a gromet to get by with
Old Dec 12, 2009 | 05:19 PM
...Roger...'s Avatar
...Roger...
Any reason you couldn't solder it in ?
Old Dec 12, 2009 | 05:56 PM
joewill's Avatar
joewill
yes, braze it in..
Old Dec 12, 2009 | 06:18 PM
Aggitated Monkey's Avatar
Aggitated Monkey
Do you have a buddy with a wire feed? That would take a few minutes with your prep. Welding shops are not cheap.
Old Dec 12, 2009 | 06:22 PM
rexx78's Avatar
rexx78
$80 sounds right, I agree with SIXFOOTER.
Brazing or soldering requires a tight fit since the brazing rod is what bonds the joint together using capilary action, rather than the parent metal being melted with filler rod added.
You can buy a small oxy/mapp torchset from Homedepot for about $50and you could weld that yourself.
Maybe you can find someone who works at a bodyshop and wants to make some cash on his lunchbreak... I got a crack in my bellhousing fixed for $20 from a guy who builds riverboats.
You know JB weld will work...
Old Dec 12, 2009 | 06:25 PM
golfradict's Avatar
golfradict
Someone with a MIG or a TIG welder should be able to do this in about 5 minutes for no more than $20.00.
Old Dec 12, 2009 | 07:54 PM
rajsid's Avatar
rajsid
Yeah, the weld shop guy said it's an hour's work to weld that thing.
I said I could pay up to $40. Then he wanted me to wait for his partner to return from lunch so that he can really do it for $40
Thanks guys, all great ideas.
I am going to call a couple of small time welders fro Craigslist first. If that does not work, I'll have to do something as folks suggested here.
Thanks again.
Old Dec 12, 2009 | 07:56 PM
rajsid's Avatar
rajsid
I couldn't find anything like that at Home Depot for $50. I would be willing to spend up to $150 if I can find something like what you suggested. I am sure it will come in handy later.
Old Dec 12, 2009 | 07:57 PM
eastltd's Avatar
eastltd
Thanks again.
Why don't you just pay the 40 bucks and be done with it?
Old Dec 12, 2009 | 08:22 PM
onaqwst's Avatar
onaqwst
jb weld it... fast/easy and looks good......
Old Dec 12, 2009 | 08:37 PM
noonie's Avatar
noonie
Too bad you aren't closer, I'd sell you a regular oxy/acet complete setup with B and Q tanks (I think, trying to remember) for the $150.00
Old Dec 12, 2009 | 08:44 PM
markids77's Avatar
markids77
That's actually a tricky weld job because the metal's so thin. I'd braze the repair myself... easier to control and less risk of burn through. A MIG is not the best for this... a TIG and an experienced hand needed not to make a mess. Or epoxy like onaqwst says... not a structural repair.
Old Dec 12, 2009 | 08:45 PM
BWH76's Avatar
BWH76
check the local muffler shops. the one's around here would do it for $20 or less
Old Dec 12, 2009 | 08:48 PM
markids77's Avatar
markids77
You could even 'glass it in if you have the resin and mat!
Old Dec 12, 2009 | 09:05 PM
rajsid's Avatar
rajsid
Because he did not want to do it for $40. I offered him that, but he want sure if he could do that. He wanted me to wait or go back there in a couple of hours when his partner returns from lunch.
Old Dec 12, 2009 | 09:12 PM
greg454's Avatar
greg454
That is not an easy weld. The picture looks like you have a pretty big gap between the pipe and the hole, and very thin metal. For metal that thin you need a much tighter clearance. If the guy does a good job that ends up looking good then $80 might not be that bad.
To Welding experts - help
Old Dec 12, 2009 | 11:35 PM
dannyman's Avatar
dannyman
Take it to a local college and have the shop do it for the cost of materials. They still do that?
Old Dec 13, 2009 | 12:00 AM
jrl77's Avatar
jrl77
A rat tail file, rubber grommet, some nice paint and you can position it any way you want !
Its inexpensive ,clean and flexable plus you did it your self.... "priceless"
Old Dec 13, 2009 | 12:07 AM
Secret Squirrel's Avatar
Secret Squirrel
I would tig that in for cold beer $80, what a dreamer.....
