steeroids in 69
Old Dec 14, 2009 | 11:19 PM
TOM B1's Avatar
TOM B1
Default steeroids in 69
any comments on steeroids. I am thinking of going with a power system for my 69.
Old Dec 15, 2009 | 02:02 AM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
I love it...
Old Dec 15, 2009 | 06:42 AM
Gordonm's Avatar
Gordonm
Great addition. I have put in 3 systems and going to be doing a forth install in a month or two. Nobody including me has been disappointed.
Old Dec 15, 2009 | 03:34 PM
MyRed69's Avatar
MyRed69
Anybody have issues with one of the steeroids U-joint set screws hitting the motor mount? I'm going to have to notch out the lower flange. I will probably weld a plate on the bottom of the mount (and then notch) to reinforce the mount unless anyone has a better way to go???
Old Dec 15, 2009 | 03:38 PM
Gordonm's Avatar
Gordonm
Yes mine hit slightly. I just ground the frame a little. Installed a shorter set screw with Loctite. No problems since.
Old Dec 15, 2009 | 09:01 PM
1969RAY's Avatar
1969RAY
There were some issues with clearance of movement when I prebuilt the unit. A little grinding and an extra washer here and there and all was fine. You may need a big hammer to remove the old system.
Old Dec 15, 2009 | 09:12 PM
mrvette's Avatar
mrvette
Same rack, did my own install in winter 01-02 before anyone hit the market with them, easy do, couple of properly supported brackets, and cut a crescent out of the lower/rear of the engine mount horn, and good to go with two U joints....
use the stock tie rod ends, more durable...
Old Dec 15, 2009 | 09:15 PM
MyRed69's Avatar
MyRed69
Default steeroids pic
Here's a pic of where i'm at. i'll take a few better ones this weekend. It's almost rubbing on the mount without the screw...
Old Dec 15, 2009 | 10:00 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i have the set up and like it, you do have to gring things here and there.....it did not hit my engine mount but i did have to grind the lower a arm so the tie rod end didnt hit it.
Old Dec 15, 2009 | 10:24 PM
1969RAY's Avatar
1969RAY
I don't remember mine being quite that close-but I'll take a look this weekend if not sooner.
Old Dec 16, 2009 | 07:50 AM
aussiejohn's Avatar
aussiejohn
Default www.borgeson.com
Tom,
Before you make a decision on Steeroids, do yourself a favour and check out the integral power steering box from www.borgeson.com. It fits straight in, although you do have to compress your steering column an inch or two. You get rid of the power ram, four old hoses that hang under the car, and gain a modern steering box that gives you a variable power assist, from very little when you're driving in a straight line, to maximum when parking.
Cost is about half of a Steeroids, and you get to keep all of the steering linkage as designed by GM, and no bump steer, either. Plus you get a three year factory warranty and the knowledge that the system is the same type of steering box that was designed for the car by GM, only with integral power assistance.
Check around for others who have used it.
Regards from Down Under
aussiejohn
Old Dec 22, 2009 | 07:03 PM
TOM B1's Avatar
TOM B1
Good idea Aussiejohn, but I bought a Flaming river tilt column and dont know if it will compress like the stock column. I could put back in the stock tilt teli.
To steeroids in 69
