1972's
Old Dec 21, 2009 | 09:32 AM
vette54728702's Avatar
vette54728702
Default 1972's
I was looking at a 1972 last night. It looks like the hood is an LT-1 hood. The hood had the chrome inserts that are divided in the middle, no stripes around the scoop, but the hood also had 454 on each side down by the chrome strips.
Was this correct? Is there anyway to tell if this car was an original big block?
Old Dec 21, 2009 | 09:41 AM
joewill's Avatar
joewill
The VIN will tell you what it came with originally.. if the 5th character is a 'W".. its a big block
Old Dec 21, 2009 | 09:45 AM
vette54728702
That exactly what I wanted... and easy to check! Thanks for the info. Now, is the radiator and fuel lines different for a big block? Any other tale-tell signs to look for?
Old Dec 21, 2009 | 09:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Was this correct?...
Yes. Correct for big block cars. The LT-1/BB hoods are the same with the exception of the numerals/stripes.
Old Dec 21, 2009 | 10:03 AM
vette54728702
So the hood scoope chrome trim (in the pocket of the scoope) is supposted to be divided for LT1 and BB ? BB will not have the stripes, but will have the 454 emblems?
Old Dec 21, 2009 | 10:07 AM
vette54728702
Also, This 1972 is a coupe. The seat belts went through a hole in the metal strip on the back of the seat. My '75 coupe does not go through the metal stip on the back of the seat, it goes around the back of the seat and mounts to the halo side. I found this interesting also.
Old Dec 21, 2009 | 12:01 PM
Easy Mike's Avatar
Easy Mike
...So the hood scoope chrome trim (in the pocket of the scoope) is supposted to be divided for LT1 and BB ? ...
Yes
...BB will not have the stripes, but will have the 454 emblems?
Yes.
LT-1 will have stripes and letters for LT-1, but will not have numerals. A genuine LT-1 hood will not have evidence of prior holes for mounting the 427/454 numerals.
Old Dec 21, 2009 | 01:58 PM
BB72's Avatar
BB72
Rear end will have bolt on caps instead of straps, if it's an air car, from what I remember it will have a tubular, not round like the sb version overflow tank on the inner fender. Just my 2 pennies.
Old Dec 21, 2009 | 10:41 PM
CCrane65's Avatar
CCrane65
Big blocks also have a 9/16" rear sway bar.
If it is a big block A/C car it is supposed to have a special cooling fan with "finger tips" that stick out past the fan shroud.
The alternator should be a model number 1100544, the starter a model number 1108400, the carb a 7042217 (manual trans) or 7042216 (auto trans).
cc
Old Dec 22, 2009 | 12:31 AM
vettebuyer6369's Avatar
vettebuyer6369
Don't forget about checking the tach red line and of course, the console data plate... and even the emissions sticker.
The question is, what's UNDER the hood? Are you saying it's an NOM?
To 1972's
