Automatic Shifter problems
Old Dec 21, 2009 | 09:30 PM
C3-76's Avatar
C3-76
Default Automatic Shifter problems
1976 car will not shift into park. Shifter says car is in park when car is actually in reverse. No obvious broken or damaged shift cables. Help!!
Old Dec 21, 2009 | 10:56 PM
oldsarge's Avatar
oldsarge
You might have a damaged or stretched cable, I can't remember if there is any adjustment at either end for that year, but check to see if any. Your cable is not pulling your linkage all the way forward into park. Hope this helps a little.
