74 coupe question
Old Dec 28, 2009 | 12:01 AM
BARRY L-48's Avatar
BARRY L-48
Default 74 coupe question
I recently purchased a 74 coupe and am redoing the interior which I have started to remove. My question is how do I remove the e-brake cover from the car,the front console and guage cluster have been removed.
Old Dec 28, 2009 | 12:08 AM
20mercury's Avatar
20mercury
Default Good to get an Assembly Instruction Manual (AIM)
Good to get an AIM which shows all of the screws and parts.
I believe you have a screw maybe a 3/8" socket head that you have to undo from inside the compartment behind the seats. Located in the center. Also a couple of screws, one on each side which you likely found already.
Hope this helps.
Old Dec 28, 2009 | 12:39 AM
aussiejohn's Avatar
aussiejohn
Regards from Down Under
aussiejohn
Old Dec 28, 2009 | 12:59 AM
curtis74's Avatar
curtis74
Hope this helps.
That's how I did mine!
Old Dec 28, 2009 | 08:14 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
The one in the back of the console is easy to get out and a pain to get back in. At least it was for me and for some reason, I had to install and remove that dude more than once for some reason.
Old Dec 28, 2009 | 10:47 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The '74 AIM will help. It shows the installation of the bolt you're looking for.
Old Dec 28, 2009 | 02:06 PM
oldsarge's Avatar
oldsarge
Now thats just funny. me too. wasn't funny then, though. just brought back an old memory and had to laugh.
Old Dec 28, 2009 | 04:27 PM
wills670's Avatar
wills670
When I put mine back in on my 72 I cut a 1/4" bolt and used it as a stud and ran it all the way thru the nut on the e-brake console and then locked it down with a nut and installed it with the new stud. It helped me a lot from trying to get a bolt started in the rear
compartment.
To 74 coupe question
