Blinker Help
Dec 28, 2009 | 10:32 AM
Blinker Help
Right blinker works fine including dash light. Left blinker is dead. Running lights work fine. Where to go from here? Thanks
Dec 28, 2009 | 11:06 AM
Start checking at the harmonica connector under the column to be sure the "juice" is getting through the turn signal switch.
edit- check the Lt blue double wire- thats the left front signal and the left front dash indicator
the Dk blue double is the right side
Dec 28, 2009 | 05:53 PM
getting power to left side, blinker lights light up when turn signal lever down but no blink action. Is there a blinker switch for each side?
Dec 28, 2009 | 06:21 PM
Quote:
Originally Posted by
Higs
Have you replaced any bulb's front or rear?
Dec 28, 2009 | 07:14 PM
GREGG-73
Bad bulb or poor ground.
(When you said above left blinker was dead I thought you meant not even a dash indicator light.)
Dec 28, 2009 | 08:02 PM
I had a bad ground on my driver rear light that drove me mad. The blinkers would flash left and then flash right. Grounds can be baffeling.
chuck
Dec 30, 2009 | 07:19 AM
Sometimes you try to over think problems with these cars. Turned out to be a bad bulb duh!
Dec 30, 2009 | 07:30 AM
Higs
Glad your off the blink! For future reference...if the
dash light remains on but does not blink when engaged....nine out of ten times its a bulb.
