Carpet install help please
Old Dec 28, 2009 | 01:33 PM
pwsusi's Avatar
pwsusi
Default Carpet install help please
This may be a stupid question, but i will ask anyway because if i am wrong and start cutting it will be money down the drain to order a new carpet set...
I'm installing rear carpet in a '71 and not 100% sure which side is which for the wheel wells. I snapped a couple of pictures of what i think goes on the driver's side wheel well...
(assuming left = bottom and right (tapered side) = top).
(assuming square hole in padding is for seat belt assembly....although it doesn't line up quite right)...
Old Dec 28, 2009 | 01:37 PM
pwsusi's Avatar
pwsusi
Jammed the other piece into place on the driver's side and it seems to look ok, so i'm thinking i'm correct...
Old Dec 28, 2009 | 01:51 PM
oldsarge's Avatar
oldsarge
your first picture is the left side being the drivers side. the tappered corner goes to the top by the top side of the door.
Old Dec 28, 2009 | 01:58 PM
pwsusi's Avatar
pwsusi
that was my assumption....thanks for confirming i'm on the right track. seems to fit best this way
Old Dec 28, 2009 | 08:33 PM
pwsusi's Avatar
pwsusi
so what's the secret to getting the carpet plugs back in? I've been struggling trying to get the rear carpet plugs back in
Old Dec 28, 2009 | 11:50 PM
oldsarge's Avatar
oldsarge
what do you mean by carpet plugs?
Old Dec 29, 2009 | 12:02 AM
RobRace10's Avatar
RobRace10
I gave up on mine, but after thinking about the tool I used (a cut off screwdriver) I should weld on a washer as a depth stop to keep the screwdriver shaft from tearing through the plugs.
To Carpet install help please
