TRW spring kit question
Old Dec 30, 2009 | 11:05 AM
NMT1957's Avatar
NMT1957
Default TRW spring kit question
Hey folks,need help,looking for opinions on install of TRW spring.I bought the install kit for the spring .There are 2 steel plats that will go on each side of the spring from top to bottom,it;s a 340 rate spring.One of the steel plates has a beveling on one side,muskegon says it is the top plate and that the bevel will face upward so that the height spacer will sit square on the inside and outside sandwiched between the top and bottom steel plates.Can anyone confirm that the beveled steel plate is the top plate and that this stepped down beveled side will face upward towards the differential cover.thank you for your input.
