Hood alignment
Old Jan 4, 2010 | 01:22 PM
kingkohlmn's Avatar
kingkohlmn
Veteran: Marine Corps
Default Hood alignment
I did do a search first, but from what I found most pertained to pre 78. My hood needs to be moved toward the passenger side. There are a few posts which say the lower bolts on the hood hinge can be loosened from underneath. My feeling is this works on pre 78, but on a 78 the reservoir for the vacuum for the head lights looks like its in the way. Has anyone done this on a 78 or later? I think I may have success if I remove the turn signal grills and remove the lower fairing assembly. Any help is much appreciated.
Thanks Bill
Old Jan 4, 2010 | 01:58 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Post a pic. How much do you want to move the hood? You have a small amount of movement in the hood hinges.
Old Jan 4, 2010 | 08:08 PM
kingkohlmn's Avatar
kingkohlmn
Tried that already, didn't help.
Old Jan 5, 2010 | 11:41 AM
Easy Mike's Avatar
Easy Mike
I'm wondering whether you've got problems other than hood adjustment. Has your car been hit?
Old Jan 5, 2010 | 09:44 PM
kingkohlmn's Avatar
kingkohlmn
My post may be a bit misleading. The car has not been hit. I feel the reservoir is in the way because you can not see around it when the lower fairing is installed. If I recall, pre 78 vettes did not have the reservoir. I am pretty sure if I remove the lower fairing, I would have enough room. Before I do this I am hoping someone can confirm they have done this on a 78 or later and it worked.
Old Jan 5, 2010 | 11:18 PM
Ironcross's Avatar
Ironcross
I used paint sticks on both sides in several locations protecting the paint with the hinges semi tight so I could jiggle it into the correct location and keep tightening and checking until firm and finished.....It lined up perfect sides, front, and including the wiper door... and I didn`t have to go under the car...nor did I even want too...
Old Jan 6, 2010 | 11:19 AM
kingkohlmn's Avatar
kingkohlmn
I guess I'll try your suggestions. I really don't want to remove the lower fairing.
Thanks Bill
To Hood alignment
