Re-torque headers
Old Jan 6, 2010 | 09:53 AM
77vetter's Avatar
77vetter
Default Re-torque headers
I am thinking about getting headers and sidepipes for my 77 and was discussing this with a mechanic friend of mine and he said that I would need to re-torque the headers a couple times a year. Is that a known problem, does everyone else retorque them or is he being over protective?
Old Jan 6, 2010 | 10:26 AM
bashcraft's Avatar
bashcraft
You'll need to re tighten them after each of the first several warm ups. After that they'll be fine.
Old Jan 6, 2010 | 10:36 AM
Golden's Avatar
Golden
I have to retighten mine periodically
Old Jan 6, 2010 | 10:53 AM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
Yep. Just took mine off for some engine updates, and a few were just finger tight... Oops.
Old Jan 6, 2010 | 11:00 AM
Duke94's Avatar
Duke94
Buy a good multi layer dead soft aluminum or copper header gasket along with Stage 8 locking header bolts (or simular) and you'll never have a leak and never have to retorque the bolts. I've had my headers and sidepipes for 7 years and never had a leak or bolt issue with this setup.
GW
Old Jan 6, 2010 | 12:20 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i have never retorqued mine (4-5 yrs)....do make sure though that they are not bottoming out before they have tightened all the way down though
Old Jan 6, 2010 | 07:47 PM
fauxrs's Avatar
fauxrs
Same with me, I havent had to retighten mine at all since the engine went in 5 years ago.
Old Jan 6, 2010 | 08:41 PM
forvicjr's Avatar
forvicjr
If you are running stock port heads,I suggest you purchase felpro manifold gaskets.Crankem down and forget about them! Much,much cheaper also,think $6.99 a set....M2Cs
Old Jan 6, 2010 | 08:51 PM
Phil Zell's Avatar
Phil Zell
They are kind of like a Trojan !, You need to check it, from time to time
Old Jan 6, 2010 | 09:55 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Definitely check them after each of the first 4-5 warm ups..if they dont come loose at all you should be good......no sense in one backing all the way out and blowing the gasket... ask me how I know?
If they are backing out keep checking/snugging them and maybe consider some magic bolts and gaskets as suggested above if they dont eventually hold.
peace
Old Jan 7, 2010 | 09:00 AM
76stingracer's Avatar
76stingracer
Here's what you need. Way easier than the stage 8 bolts. They are a little pricey but will never come loose.
http://www.summitracing.com/parts/PHP-21003/
Just verify the size you need.
To Re-torque headers
