I know there is a difference in the rear section from a coupe to a vert (as stated above), but I also think that they cut the front carpet slightly different between 4spd and automatics.
I am not 100% positive, but may be a good idea to check.
...but I also think that they cut the front carpet slightly different between 4spd and automatics....
Yep. Right front tranny hump is just a little bit bigger for AT cars. Tunnel was trimmed and an extra piece bonded in to clear the TH400. AT carpet can probably be trimmed to fit the 4 spd okay.
