Front end help please
Old Jan 13, 2010 | 03:00 PM
81coupeowner's Avatar
81coupeowner
Default Front end help please
[URL="http:// I'm finally Putting the front end back together but can't remember which end of the spring is up. Can someone help me with this?
Old Jan 13, 2010 | 04:35 PM
crvtownr's Avatar
crvtownr
IIRC it doesn't make any difference. Be sure that the spring is seated properly in the top spring pocket before compressing, and that the end of the coil does not cover the holes in the lower a-arm pocket as they allow water to drain.
Old Jan 13, 2010 | 04:49 PM
81coupeowner
thank you crvtownr that helps alot.
Old Jan 13, 2010 | 10:29 PM
Artsvette73's Avatar
Artsvette73
The close spaced coils go up in the frame pocket
Old Jan 14, 2010 | 11:49 AM
Vampyre's Avatar
Vampyre
+1
To Front end help please
