78 spring mounts
Old Jan 13, 2010 | 05:35 PM
mlars's Avatar
mlars
Default 78 spring mounts
Hi, Im new here. I just got a 78 vette. Im going to put new rear spring mounts on it at the end of the springs, my question is that the spring seems to be too far back because the bolts are angled back and wedge on the trailing arm and spring, even when I jack up on the spindle mount but its better. There not up and down straight with each other. Has anyone run into this? DoI need to take the spring off. Maybe its bent.
Old Jan 13, 2010 | 10:57 PM
gjohnson's Avatar
gjohnson
Post a pic if you can.
Old Jan 14, 2010 | 08:59 AM
mlars's Avatar
mlars
Default pic help
I will put a pic of it. Have never done it.
Old Jan 14, 2010 | 11:30 AM
mlars's Avatar
mlars
Default trim tag
I only have one trim tag on the door post that says chevrolet J01 trim 19C 13U 07M paint, But there is not another trim tag on it like it says on the other sites in the engine bay cowl, should there be? I dont know the date J01 either. Im tring to find out how early it is and if it might have the narrower spring because of that. Still have to get pic of spring mount.
Old Jan 14, 2010 | 11:55 AM
crvtownr's Avatar
crvtownr
Welcome to the forum.
Take a look, hopefully this helps
I think you are describing the spring mounting bolts, from spring to TA. When I did my rebuild, I raised the trailing arm to the right height and used a socket to hold it up in the frame pocket. To do this though, the strut rod, shock were all disconnected and the trailing arm was free. If you disconnect the shock only you should be able to get enough movement up to line the bolt up.
Also, take caution in where you jack things up. Pressure under the bearing mounting "ear" is not a good idea.
HTH
Old Jan 14, 2010 | 12:06 PM
mlars's Avatar
mlars
Default Thanks
It does help, the bolt is at an angle, I thought it should be straight up and down. Do you know what the date code J01 is it october 1st of 77?
Old Jan 14, 2010 | 12:31 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...But there is not another trim tag on it like it says on the other sites in the engine bay cowl, should there be?
No. Corvettes have only one trim tag on the driver's door hinge post.
Old Jan 14, 2010 | 12:33 PM
BKarol's Avatar
BKarol
J = June of 1978 (A= sept of 77)
19c = black cloth/leather
13 = silver
07 = dark gray
Old Jan 14, 2010 | 12:53 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by karol
...13 = silver...07 = dark gray
Silver Anniversary car; B2Z paint.
Old Jan 14, 2010 | 01:34 PM
mlars's Avatar
mlars
The spring that is on it is a 7 leaf 2 1/4". I noticed yours in the picture is the same. Is that a special suspension that doesnt have the 9 leaf? Mine does not have a sway bar, but there are two holes on the top of the trailing arm, is that where the sway bar brackets would be. Sorry, just trying to figure out weather someone changed it or if this is the spring that came on it.
Old Jan 14, 2010 | 01:56 PM
Easy Mike's Avatar
Easy Mike
...Mine does not have a sway bar, but there are two holes on the top of the trailing arm, is that where the sway bar brackets would be...
Only the FE7 cars got the rear sway bars; the mounting holes for the sway bar brackets are in all the later trailing arms.
Go here http://www.corvetteactioncenter.com/...x.php?cmd=area and see if you can obtain a copy of the original dealer invoice for your '78. The invoice will list all the options, prices, original dealer, date shipped, etc.
Old Jan 14, 2010 | 02:20 PM
mlars's Avatar
mlars
thanks, many questions comming and discussion.
Old Jan 14, 2010 | 02:27 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
That sounds like an aftermarket gymkhana spring. ORIGINAL gymkhana spring would be 6 leaves.
There should be a 1/8" shim in front of and in back of the spring where the four mounting bolts are.
Seems a common mistake is replacing a standard rear spring with a heavy duty gymkhana spring and not making any changes to the front springs.
Old Jan 14, 2010 | 03:49 PM
mlars's Avatar
mlars
That is what hapend. There are no shims between the bolts and the spring and there is pleanty of room to put a 2 1/2" spring.
Old Jan 14, 2010 | 10:32 PM
KapsSA's Avatar
KapsSA
Here's a pic with the shims.
The bolts at the trailing arms WILL be slightly angled when the suspension is hanging. You should be able to push down on the spring end enough to get the bolt out. The gymkhana spring doesn't have as much arc as a standard spring. When you jack the gymkhana spring end up to remove the nut on the bolt, you should be able to completely release the jack from the spring without any problem.
Old Jan 15, 2010 | 09:45 AM
mlars's Avatar
mlars
That is a graet pic of of the spring. The spring in mine has 7 leafs and a flat plate at the top of it. No shims. I heard if I want a smooth ride, I should put the original 9 leaf back in. Car is just stock. 185hp woo hoo! I may change that down the road, but only to 275 hp or so.Thanks for the pic, now I know there should be a heat shield there also, or was there on a 78?
To 78 spring mounts
