rear window removal on 74
Old Jan 23, 2010 | 09:52 AM
Sundevil64's Avatar
Sundevil64
Default rear window removal on 74
any special tricks other than don't break the glass when removing the rear window out of a 74? It had been sealed with clear silicone along with the windoe sealant. I'm prepping the car for paint and was going to take out the window and reseal. Just cut away with a sharp knife correct and remove?
Thanks.
Old Jan 23, 2010 | 09:36 PM
BARRY L-48's Avatar
BARRY L-48
Default window removal
Just removed the rear window in my 74 coupe. I am also prepping for paint. I removed the inside frame and just cut around the window and gently push around the glass. Good luck!
Old Jan 23, 2010 | 10:33 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
xzylene from the paint section at a home depot will remove the adhesive from the gasket
Old Jan 24, 2010 | 12:15 AM
Sundevil64's Avatar
Sundevil64
Default window
Thanks guys.
To rear window removal on 74
