81 resto Reuse or Replace?
Old Jan 24, 2010 | 09:26 PM
jomor's Avatar
jomor
Default 81 resto Reuse or Replace?
Parts like sway bars (new or refinish and replace bushings), steel rear spring on my 4 speed( composite or rebuild old one), front springs(can they be refurbished ir is it cheaper to replace). Not doing an Ncrs but would like to stay close to stock on most things.
Old Jan 24, 2010 | 09:34 PM
markids77's Avatar
markids77
Sway bars refinish. A composite rear spring will improve both ride and handling, and a set of fronts matched to the rear will give most balanced handling.
Old Jan 24, 2010 | 10:09 PM
mds3013's Avatar
mds3013
Unless ride height is too low due to damaged springs keep all original parts on car as long as you can. Just my thoughts, mds...
To 81 resto Reuse or Replace?
