What is this on the firewall
Old Jan 25, 2010 | 08:22 PM
joefish's Avatar
joefish
Default What is this on the firewall
I am new to the forum and love it. I have found answers to many questions already but this one I can't figure out. I have a 79 and on the firewall behind the driver side valve cover is some kind of valve. It looks like it gets a vacuum hose and has two terminals for wires. Anyone know what it is and where does the wires and hose come from. Help would be greatly appreciated. Thanks
Old Jan 25, 2010 | 10:31 PM
nw2571's Avatar
nw2571
Would really help if you could take a picture. Not sure about the vac hose, but it kind of sounds like you might be describing a ballast resistor. People usually mount them in this area.
Can't really tell you unless you post a picture I guess... Sorry!
Old Jan 25, 2010 | 10:34 PM
earthquake68's Avatar
earthquake68
Is it stock? Sounds like a MAP sensor. They didn't have them until '82, though. A picture sure would help.
Old Jan 25, 2010 | 11:55 PM
joefish's Avatar
joefish
There are two pictures in my album I hope this helps.
http://forums.corvetteforum.com/pict...ictureid=44202
Old Jan 26, 2010 | 06:26 AM
corvetteload's Avatar
corvetteload
Part of disabled cruise?!?!?!?!
Old Jan 26, 2010 | 10:11 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Can't see it too well. Might be transmission kick down switch. Do you have the '79 AIM? If it's stock, the AIM will show it.
Old Jan 26, 2010 | 10:17 AM
earthquake68
Wow, that doesn't happen much on stuff like this. I've never seen a part similar to that on anything. I have absolutely NO idea what that is. It looks like a vacuum operated electrical switch. That is, when a certain vacuum is reached, it turns the switch on/off. Now I HAVE to find out so I know for the next time.
Old Jan 26, 2010 | 11:19 AM
...Roger...'s Avatar
...Roger...
I've seen a very similar switch used to shut the AC compressor off during heavy acceleration but it is usually over next to the compressor.
I've also seen the switch used to open and close the headlights instead of using the vac switch on the headlights.
Years ago 1 of the vendors sold a kit with a vac switch that made 1 of the headlights "wink".
Old Jan 26, 2010 | 01:59 PM
joefish's Avatar
joefish
A friend said it might be some kind of transmission kick down switch but not sure. We could not figure out how it should be hooked up. In the close up pic you can see its mounted to the firewall with two rivets and a bolt. I don't think it was an aftermarket thing.
Old Jan 26, 2010 | 11:40 PM
69VetteAngel's Avatar
69VetteAngel
On one of my older car aquisitions, there was a valve similar to that for a water injection system that was once installed on the car. it was a vacuum operated switch with 2 elect. terminals . I later found out it was a Holley water injection kit. Still kept the switch around in my toolbox.
Good luck.
Greg.
Old Jan 27, 2010 | 05:39 PM
killain's Avatar
killain
Oldtimer
I had a 79, and if you mean the round thing with two vacume lines, that's the vacume filter. I replaced mine once.
Old Jan 27, 2010 | 06:13 PM
CCrane65's Avatar
CCrane65
killain, click on the link below the picture. There's a better shot of what he's talking about.
cc
Old Jan 27, 2010 | 06:35 PM
nw2571's Avatar
nw2571
Any chance this car has or did have a computer controlled transmission on it, like a 700R4? The kits to put these into non-computer-controlled cars has a vac operated switch to control lockup.
One example:
http://www.jegs.com/i/TCI/890/376600/10002/-1
Old Jan 27, 2010 | 09:47 PM
joefish's Avatar
joefish
Default Torque converter lock-up kit
I think your right nw2571. I did some searching on the internet and on the car and found a few things. Under the dash I found a toggle switch hooked up to a power source and going through the firewall to a green wire that goes into the trans. It looks like it was a torque converter lock-up kit. Im not really sure what it does and not to sure if I should hook it back up. Any thoughts.
Old Jan 27, 2010 | 11:19 PM
nw2571's Avatar
nw2571
Can you tell us what tranny is in the car?
Old Jan 27, 2010 | 11:30 PM
joefish's Avatar
joefish
It's an automatic with the Turbo Hydra-Matic 350.
Old Jan 27, 2010 | 11:51 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
If your car in an 80 LG4, then it could be the lock up switch for the torque converter. 81's used the computer to do it but both models had the TH350C transmission.
I've never seen the vacuum switch and there shouldn't be a toggle switch (might have been added) but that could be it.
Old Jan 29, 2010 | 11:44 AM
joewill's Avatar
joewill
Doc Rebuild would probably know.... if its factory....
Old Jan 29, 2010 | 09:28 PM
doctorgene's Avatar
doctorgene
That is the 350 Lock up vacuum switch, AC Delco # 212-331 or GM # 14032087 Have a great day. Gene
To What is this on the firewall
