Aluminum Flywheel
Old Jan 31, 2010 | 02:04 PM
68vetteman's Avatar
68vetteman
Default Aluminum Flywheel
I was wondering if anyone who had a steel flywheel and changed to an aluminum one noticed a difference in drivability? Example: Is it harder to start out from a dead stop because the flywheel is lighter?
68 Vetteman
Old Jan 31, 2010 | 04:19 PM
Gordonm's Avatar
Gordonm
Not harder just different. You have plenty of torque to get the car moving. It took me about 10 minutes to get used to it. Now I don't even notice it taking off. It does rev much quicker. Highly recomend a lighter flywheel.
Old Jan 31, 2010 | 06:59 PM
lowbuck72's Avatar
lowbuck72
A lighter flywheel will give you the lopey idle we like with a milder camshaft. To save money, you can always have a steel flywheel machined to be lighter rather than buying aluminum. If you're really cheap like me, you can drill a bunch of 3/8" - 1/2" holes in it to remove material, and then balance it out on a wheel balancer, drilling holes on the heavy end. Those machines can get it down to 5gr imbalance.
Old Feb 1, 2010 | 02:06 AM
JohnRR's Avatar
JohnRR
Lighter is almost always better when it comes to rotating mass. I had a Fidanza aluminum flywheel and really didn't like it. Yes, it requires you to slip the clutch a little more carefully. After I sold the car, the new owner told me that he stalled it 6 times just trying to get it in his garage!
Next time I'll buy something a little bit heavier, like a light weight steel flywheel.
John
Old Feb 1, 2010 | 02:24 AM
RunningMan373's Avatar
RunningMan373
Nothing like having a flywheel come apart at 5k RPMs,, oh the memories.
Old Feb 1, 2010 | 07:11 PM
Rmorgan&11's Avatar
Rmorgan&11
I've Kaboomed Clutches !!! I would hate to have a flywheel trying to come thru the floor
Old Feb 1, 2010 | 07:42 PM
68vetteman's Avatar
68vetteman
Thanks for the input guys. I think I'll go with the steel billet flywheel.
68 Vetteman
To Aluminum Flywheel
