quick auto tranny detent wire question.
Old Jan 31, 2010 | 11:08 PM
69VetteAngel's Avatar
69VetteAngel
Default quick auto tranny detent wire question.
Just a quick question: The '69 auto transmission detent wire that travels from under the dash out to the tranny: where does it go through the bulkhead? It is not on the service manual wiring schematic, and it was just loose through one of the bulkhead holes. Does it get a special grommet, or does it go along with the tach cable?
Also, Anyone know where the windshield wiper door vacuum solenoid switch attaches to in the interior compartment? Mine was just screwed in to the side of the console. I know it can't be far from here, because of the wire length, but I would like to put it in its' correct place.
Once again, Thanks,
Greg.
Old Feb 1, 2010 | 11:41 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 69VetteAngel
...where does it go through the bulkhead?...
Check the AIM under the M40 option section. It will show the wire and the routing.
...Anyone know where the windshield wiper door vacuum solenoid switch attaches to in the interior compartment?...
On the upper rear of the tachometer. AIM shows the installation.
Old Feb 1, 2010 | 11:21 PM
69VetteAngel
Thank you Mike. I have to pick up the AIM manual. I'll check it out once I get it.
Thanks for the info,
Greg.
Old Feb 2, 2010 | 09:02 AM
Easy Mike's Avatar
Easy Mike
...I have to pick up the AIM...
AIMs are worth the cost; they are helpful.
To quick auto tranny detent wire question.
