Body mount install help needed.
Old Feb 18, 2010 | 10:48 PM
cherrybombc3's Avatar
cherrybombc3
Default Body mount install help needed.
I am replacing some body mounts. Is there a torque spec or procedure to tightening them or just snug em down till they bulge slightly?
Also, has anyone found a good quality grade (not poly) body mount. I have replaced mine twice in 4 years (same vendor). Again they are cracked & spider webbed. Heck they look 25 yrs old.
Old Feb 19, 2010 | 12:45 AM
Grumpy 427's Avatar
Grumpy 427
I torqued mine to 45 lbs, scared to go any more. Mine are the polly ones, and after a week 3 of them cracked in half. So i keep checking them to see what shape they are in. I started from the middle of the car, then worked my way out making sure they were even all the way around. going no more than 5 ft lbs at a time.
Old Feb 19, 2010 | 01:10 PM
cherrybombc3
Mine are rubber, I'll go 45 & give a visual evaluation at that point.
I cant beleive the crud these replacement mounts are made of. They are dry rotted or just cracked after 2 seasons and look 25 yrs old, twice now!! My local GM dealer said if I can find the GM part number he thinks he may be able to get some OE GM's somewhere???
Old Feb 19, 2010 | 01:36 PM
Grumpy 427's Avatar
Grumpy 427
Yeah its a shame alright.I was at my buddy's resto shop, he is rebuilding a 96 GTO and the factory body mounts were in great shape, mind you this car has not seen winter obviously.
To Body mount install help needed.
