Adhesive remover?
Old Feb 20, 2010 | 06:22 PM
RedAirRdstr's Avatar
RedAirRdstr
Default Adhesive remover?
I am trying to clean up the floorboards in the vette to prep for paint or a coat of bedliner, but a previous owner used enough glue to keep the carpet in place through a hurricane. Is it ok to use something like goo gone or 3M adhesive remover on the fiberglass? I really just want to remove the glue and not the paint underneath it.
Any suggestions?
Thanks, Jeremy
Old Feb 20, 2010 | 07:33 PM
oldsarge's Avatar
oldsarge
3M adhesive remover, should be safe, but not knowing what type of paint you have their, I would try a small, unseen area first, just to be sure.
Old Feb 20, 2010 | 08:53 PM
killain's Avatar
killain
Oldtimer
I've used the 3M product on a few jobs and it always worked out great. You could also use mineral spirits as well and use a 3M scuff pad with the adhesive remover will make the job go a lot faster.
To Adhesive remover?
