C5 wheels on a C3
Old Feb 22, 2010 | 08:47 PM
rockstarZ06's Avatar
rockstarZ06
Default C5 wheels on a C3
Does anyone know if its possible to put C5 Z06 wheels on a C3. I was think there may be a way of doing it but I havent been able to find anyone that has done it.
Old Feb 22, 2010 | 10:11 PM
captl27's Avatar
captl27
you might have better luck on the tech forum. I have c5 wheels on my 79 but i have offset rear swing arms and I used 2 1/2 inch spacers, Vette brakes has them along with others and even E bay
Old Feb 23, 2010 | 03:17 PM
wfdlt8's Avatar
wfdlt8
Yellow c3's are awesome.
Old Feb 23, 2010 | 03:26 PM
Leung's Avatar
Leung
Ive seen someone here done it. Hopefully they will chime in.
Old Feb 23, 2010 | 07:27 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
There are a few here that have them, BJ was one of the first
Here is mine
Neal
Old Feb 23, 2010 | 09:13 PM
myc3's Avatar
myc3
Here is mine
Neal
Are any of these wheels possible with stock trailing arms? I just replaced mine and I did not buy the offset ones.
Old Feb 24, 2010 | 12:21 PM
myc3's Avatar
myc3
Can this be done if you don't have the offset trailing arms? What options are available for those of us who have standard trailing arms?
I have seen 17x8 ZR-1 style wheels in the Corvette Central catalog that say they will fit 68-82 without spacers.
Are there other options?
Old Feb 24, 2010 | 05:44 PM
bluegtp's Avatar
bluegtp
yup it can be done with a stock suspension....I used adapters and relocated rear ebrake bracket along with a new shortened fiberglass rear spring. I didn't fit them with the old spring on so i can't tell you if works with the stock length or not with 18x10.5 in the rear.
Old Feb 24, 2010 | 08:11 PM
chevymans 77
My TA's are stock other than moving the e-brake bracket to the top of the TA.
Also runing adapters
Neal
Old Feb 24, 2010 | 09:16 PM
myc3's Avatar
myc3
Neal
I really like the profile of your tires and the way they fill the fenders. What size are the wheels and tires. What size adapters? Did this make a difference in ground clearance? What speedometer gear changes were required?
Sorry for all the questions.
Thanks for the info.
Old Feb 24, 2010 | 10:07 PM
OURSHARK's Avatar
OURSHARK
You have a sweeeet vette Art.
Old Feb 25, 2010 | 08:47 AM
captl27's Avatar
captl27
Thanks Fred so is yours.
I did alot of research before I was able to pick these used wheels and tires off craigslist (see My Corvette Photos). (most of us have budgets) There are a many different sizes of C5-C6 wheels out there and there are also different sizes of adapters. here is a website that has mostly C5 wheels with there sizes and there offsets. Also a web site with adapter sizes. I am not recommending these manufacturers but use them for information. I am not not recommending them ether. Also if you look through this sites photo albums you will find C5 wheels with different tire sizes on them. Mine are BF Goodrich G force tires 255/40 ZR17 Fronts, 295/35 ZR18 the rear are very wide but there are guys with wider. alot of guys use 275/35 or 40 which might work better with regular trailing arms
http://stores.ebay.com/O-E-Wheels
http://stores.ebay.com/EZ-Accessory_..._sasiZ1QQ_vcZ1
Old Feb 25, 2010 | 06:02 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Just wait 'till you have to buy tires for those C5 wheels.
BIG difference in cost over tires for C3 wheels.
To C5 wheels on a C3
