transmission switch loose
Old Feb 27, 2010 | 06:53 PM
auburn85ots's Avatar
auburn85ots
Cruising
Default transmission switch loose
I have a 400 turbo that isn't kicking down. I found the transmission control switch hanging by a wire under the dash. Where should it connect and could that be the problem?
Thanks, Davis
Old Feb 27, 2010 | 09:13 PM
TimAT's Avatar
TimAT
That could be a problem- that switch mounts to the bracket that the accelerator pedal arm pivots in. Should have 2 wires-
Old Feb 28, 2010 | 09:10 AM
auburn85ots
Cruising
thank you
To transmission switch loose
