1969 Convertable
Old Feb 28, 2010 | 08:22 PM
gw1972's Avatar
gw1972
Default 1969 Convertable
I'm changing out the engine wiring harness. Need some advice about the wiring coming through the fire wall, through a grommet, leading to "I think" the light switch? This line is tied in the main engine wiring harness w/in the engine compartment. I'm not sure whether this is part of the engine wiring harness or separate? Asking before I cut. Where does the engine wiring harness end up underneath the front bumper, head lights, etc? I'm not an automotive electrician, thanks.
Old Feb 28, 2010 | 08:27 PM
ED69ray's Avatar
ED69ray
engine and dash harness' are seperate - they plug together at the firewall
Old Feb 28, 2010 | 08:33 PM
gw1972's Avatar
gw1972
Thanks. I thought they would plug into one another at or outside the firewall however, I haven't seen where they do as yet? The line runs through the drivers side fire wall, through the grommet and towards the upper left direction, in the headlight switch direction.
Old Feb 28, 2010 | 08:39 PM
ED69ray's Avatar
ED69ray
this should help - and don't worry she looks much better now
Old Feb 28, 2010 | 09:25 PM
gw1972's Avatar
gw1972
thanks again.
Old Feb 28, 2010 | 09:47 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
You should have an engine wiring harness (from firewall plug to ignition, wipers, blower motor and starter in one direction, horn relay in the other) and a forward lamp harness (from firewall plug to temp sender, brake positioning valve, alternator and forward lamps.) This second harness has the fiber optic component (6 cables wrapped together) that breaks out and goes thru a firewall grommet (just to the outside of the dual firewall plug) and heads up to the underside of the dash, then down into your center console display.
Old Feb 28, 2010 | 09:55 PM
gw1972's Avatar
gw1972
Thanks. I'll follow the above info. to trace everything through. Do you have a wiring diagram for this 69 convertible?
Old Feb 28, 2010 | 10:35 PM
Faster Rat's Avatar
Faster Rat
You really need to get yourself a copy of the '69 AIM (Assembly Instruction Manual) that contains layout drawings of all the wiring harnesses as well as wiring schematics. The AIM is available in print and on CD from various vendors.
Old Mar 1, 2010 | 08:29 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...You really need to get yourself a copy of the '69 AIM (Assembly Instruction Manual)...
C-o-n-v-e-r-t-i-b-l-e
Old Mar 1, 2010 | 08:33 PM
gw1972's Avatar
gw1972
thanks.
Old Mar 2, 2010 | 11:10 AM
jetjockey's Avatar
jetjockey
GW, if you want some pics of the completed install of your harnesses pm me.
To 1969 Convertable
