majob brake problems.
Old Mar 1, 2010 | 01:58 PM
meinthe73's Avatar
meinthe73
Default majob brake problems.
i have a 73 with power brakes. i have replaced the m/c and bled the brakes 3 times. the pedal is only firm the first couple of days then gradually begin to get soft till it will finally hit the floor. can some one please help me with what could be causing this issue. i know it must be getting in air but i dont know where. i it does not leak. so any help would be greatly appreciated.
Old Mar 1, 2010 | 02:19 PM
The13Bats's Avatar
The13Bats
if you are getting new air in after a bleed then you would have to see it bleed out....my brakes have two bleeds each caliper and two on the MS....
Old Mar 1, 2010 | 02:20 PM
schmegeggie's Avatar
schmegeggie
This is possibly the most discussed issue in this forum. You can try searching and you'll probably find the answer.
My guess is a leaking rear caliper, or that it is sucking in air.
Old Mar 1, 2010 | 02:26 PM
meinthe73's Avatar
meinthe73
thats what iam think. how would i figure what caliper it is?
Old Mar 1, 2010 | 02:31 PM
The13Bats's Avatar
The13Bats
So then that caliper when bled would show air in it....
You know I use search and many times find making it a fresh post gets new eyes and ideas and replies on a subject....99% of the time when a newbie with a question pops into the Laser for I have answered it more than once before...when I tell them about "search" I also give a link to a possible answer....seems more kind and friendly to me...after all the forum is about helping people...just food for thought...
Old Mar 1, 2010 | 02:33 PM
schmegeggie
Does it matter? You have a 50/50 chance if you guess. Replace both of them to be sure. The rears are particularly susceptable to leaking due to the design, which is why the o-ring calipers are better for the application.
Contact VB&P, send your cores for swap or rebuild, they are the best to deal with.
P.S. I'm not trying to be a smart a$$, but you could spend the time and effort trying to find which rear caliper is leaking, replace or fix it, bleed 3x, drive it for 2 months, have the same problem and do it all over again. Or you could fix/replace them both and know they're good.
Old Mar 1, 2010 | 02:41 PM
schmegeggie
Bats,
You make a good point about giving a link, I was just too lazy to do it today
My caliper was leaking(badly), so it was obvious. When I got into my brakes 3 years ago, I had the same quandry. I remember someone posting the possibility that the caliper may not leak fluid, but may be sucking air into the piston seal if it is misaligned. I suppose that is possible that it would hold brake pressure(for a short time), not leak, and still draw in air.
Old Mar 1, 2010 | 02:47 PM
The13Bats's Avatar
The13Bats
Believe you me I get lazy too...but I know how it feels on the other end to be told "Go look it up"
On another note, I have done business with Ken and met him at this past NCRS meet...a great guy and he tells me most Corvette parts houses buy the calipers from him....
Ken McCormick
Lonestar Caliper Co.
11299 Interstate 20
Canton, TX 75103
903-829-8400 Fax 903-829-8405
www.lonestarcaliper.com
ken@lonestarcaliper.com
Old Mar 1, 2010 | 06:30 PM
Manuel Azevedo's Avatar
Manuel Azevedo
If your driving this car after the bleed job and then get the soft pedal I would check the runout on your rotors. If you have too much runout you will suck air in by the seals with no leak to the out side, you should have no more than .002 runout and that would be on the verge of to much, check them out!
Old Mar 1, 2010 | 07:15 PM
Roadking's Avatar
Roadking
How are the brakes being bled?
To majob brake problems.
