Shifter Slide Install Question
Old Mar 3, 2010 | 09:10 PM
irvan's Avatar
irvan
Default Shifter Slide Install Question
What do you have to do to put in new upper and lower shifter slides in the console, they are missing? Thanks.
Old Mar 3, 2010 | 09:20 PM
71406's Avatar
71406
On my 71 you remove the shifter plate and you will see a slot to insert the new upper and lower slides. Then re-install over the shifter handle. I assume your 74 will be the same.
Old Mar 3, 2010 | 09:58 PM
irvan's Avatar
irvan
Thanks!
To Shifter Slide Install Question
