Rubber fuel line size?
Old Mar 4, 2010 | 02:37 PM
mensch53's Avatar
mensch53
Default Rubber fuel line size?
I am running to the parts store tonight after work, but I forgot to check what size the rubber fuel line is that runs between the hard fuel line and the carb on my '72 with a 350. I assume this is pretty standard. Can someone give me the size?
Thanks!
Old Mar 4, 2010 | 02:46 PM
larryg3's Avatar
larryg3
are you sure you want to use a rubber fuel line???? after i have heard of many corvettes going up in flames i made sure that i removed the rubber line that the previous owner had installed and i bought a steel line. Now i feel a little safer. One less problem in need to worry about. just my .02
Larry
Old Mar 4, 2010 | 02:51 PM
Frogday's Avatar
Frogday
Over the years they get cut for whatever reason. A new steel line is around $30ish. It will probably take 3/8" rubber fuel line to connect what you have.
Old Mar 4, 2010 | 03:02 PM
mensch53's Avatar
mensch53
Yeah, I am going to work on a more permanent solution, but this will get me going in the meantime.
Old Mar 4, 2010 | 04:23 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
--> 3/8" will work for the majority of delivery connections. 5/16" for vapor recovery, IIRC.
To Rubber fuel line size?
