Not savy on corvette terms
Check out this thread and see post #21. Thats a birdcage.
http://forums.corvetteforum.com/c3-t...rd-cage-2.html
rare and highly desirable= base optioned high production model year
original paint= if you can see bare fiberglass, this is probably true, if not, assume hit in the front.
fresh repaint (especially if changed to "resale red") = frame rot so bad, the only thing holding it together are the body mounts.
needs a little TLC = money pit. While there's a certain amount of pride one can take once finished, you'll be hard pressed getting your spouse or banker to agree with your use of money and 4 years (or more) of your life
completely stock = most of the hard to find (and therefore expensive) pieces have been changed out with stuff you can buy at Autozone
Why did I have to start this? The rest of you guys are slipping
BTW, welcome, and good luck with your new toy. /:\
