383 stroker headers
Old Mar 8, 2010 | 03:48 PM
canabait's Avatar
canabait
Default 383 stroker headers
I'm installing a Blueprint stroker in my 76 (former L-48). The exhaust ports on the block are oval but the header is round where the header and block would be bolted together. Shouldn't the header flange be oval also? If so, any recommendations as to type or brand?
Old Mar 8, 2010 | 05:30 PM
Hogwild's Avatar
Hogwild
i'm running edelbrock perfomer rpm head's.
they have d port's and hookers have d port's .
that's not much help but all i know is what i got .
good luck
typical white person
Old Mar 8, 2010 | 07:36 PM
BKbroiler's Avatar
BKbroiler
Your exhaust ports are on the heads, not the block. What kind of heads are they? I never heard of oval ports on a SBC.
Old Mar 8, 2010 | 07:41 PM
nomocrap's Avatar
nomocrap
Blueprint uses Vortec heads
Old Mar 8, 2010 | 08:00 PM
canabait's Avatar
canabait
Sorry, the exhaust ports are on the heads (where else). Perhaps square ports with rounded corners would be a better description. The heads are cast iron GM Vortec.
Old Mar 9, 2010 | 12:30 PM
BKbroiler's Avatar
BKbroiler
I have cast iron GM Vortec heads on mine. I'm using conventional Dynamax headers with 1 5/8 inch primaries. I use gaskets for standard heads, not Vortecs. They fit, no leaks.
Old Mar 9, 2010 | 05:17 PM
Ganey's Avatar
Ganey
Default 383 headers
The Dynomax (Flowtech) full length & Hooker super comp flow great.
Old Mar 9, 2010 | 07:25 PM
tigers123's Avatar
tigers123
Sanderson cast headers have extremely big ports. qp1000
To 383 stroker headers
