points or HEI
Old Mar 19, 2010 | 02:59 PM
terrible_buddhist's Avatar
terrible_buddhist
Default points or HEI
which are you running?
I am having that 'engine dropping out' while cruising thing which I am pretty sure is the points or the coil...so considering just going to the HEI and being done with it.
Which way did you go?
Old Mar 19, 2010 | 03:34 PM
The13Bats's Avatar
The13Bats
One of the first things I bought for my 69 was an HEI,
If you are not all hung up for Purist stock go HEI or at the very least electric ignition rather than points....
Old Mar 19, 2010 | 03:58 PM
Mike Ward's Avatar
Mike Ward
When my engine dropped out it was a badly rusted frame.
gbvette62's Avatar
gbvette62
I would suggest that you concider one of the electronic ignition conversion kits. That way you can keep your regular plug wires, tach drive distributor and the stock appearence, if that matters to you. Be aware, if you want to use ignition shielding, HEI distrubutors will not fit under stock 74 and earlier top shields and brackets. Also, if you go with a regular GM HEI, you'll need to replace your tach with an electric one from a 75-77 Corvette. You can buy aftermarket tach drive HEI distributors, they run about $300. With one of these, you don't have to change your tach, but your shielding still won't fit.
Ganey's Avatar
Ganey
Points will work, my old first cars came w/ points. I was running a mag. when I bought the Corvette. If it had not come w/ HEI, it would have had a mag. in the 70s.
Gave away my dwell meter a long time ago.
Old Mar 19, 2010 | 04:17 PM
terrible_buddhist
Old Mar 19, 2010 | 08:47 PM
my 76 ray's Avatar
my 76 ray
Both.
The '76 has HEI, the '74 has points.
Old Mar 19, 2010 | 09:01 PM
AWilson's Avatar
AWilson
There is nothing wrong with a properly set up points system. You won't know the difference and they are not the maintenance headache that people say. That said, there is nothing wrong with upgrading either.
Old Mar 19, 2010 | 09:18 PM
Priya's Avatar
Priya
The last car that I had with points kept burning them out every couple of thousand miles, no one could figure out why. I changed to electronic ignition and was much, much happier.
Old Mar 19, 2010 | 10:05 PM
jae1971's Avatar
jae1971
HEI. You can get them with tach drive for less than 100.00 on e-bay.
Old Mar 19, 2010 | 10:19 PM
vettme's Avatar
vettme
HEI all the way! I ran with a GM HEI set up for yrs. Now have MSD dis. and CRANE Cams HI-6 with rev. limiter. I did go with a '75 Tach. Cable driven suck anyway no love lost there. Idle quality,cold eng starting, eng performance, and even gas mil. will all improve. Do it , you wont regreat it!
Old Mar 19, 2010 | 10:48 PM
ozzyrulesme's Avatar
ozzyrulesme
DO you have to pull the tack to convert it to hei from points? thanks...
Old Mar 19, 2010 | 10:57 PM
redcruz1120's Avatar
redcruz1120
St. Jude Donor '09
With a little effort you can make the shield fit.I was told from the seller of the HEI that it would not fit and that alone made it a challenge.The reason I would go with a HEI is that you can walk right in to your local auto parts and buy a rotor,cap,Coil.Ect,Ect..If you had to.I tried one of those conversion kits and when it left me stranded on the road the nearest auto parts store did not carry it.
Old Mar 19, 2010 | 11:10 PM
Road-Race Vette's Avatar
0Road-Race Vette
Former Vendor
Before you make any rash decisions, make sure that it is the ignition that has a problem. "Cutting out", could be a loose wire(not just a spark pug wire) etc... Does the car missfire at idle? Have you checked the gap on your points? They can get a bit quirky if they sit for a while, and might just need some cleaning or replacing.
To points or HEI
